superjeezus wrote:...is that in Rewire mode? Because I know Bidule is multi-core friendly in stand-alone mode, but I too thought that was a limitation of Rewire.
If that demo is with Bidule in Rewire mode, please share how you set up Bidule's/DP's preferences!
Bidule is in ReWire mode.
There's really no secret to it. I'm not a Bidule expert. The basic settings I've started with have just worked so I haven't messed with them since.
DP and Bidule are at 512 buffer. I always work at 512 buffer in DP. (I've learned over the years that super low buffers tend to lead to all sorts of unexplainable problems. Plus you can't do as much as you can with a higher buffer. So, I just deal with the extra latency of 512.)
-I didn't make any adjustments in DP to work with Bidule.
-Here's a pic of the ReWire settings in Bidule: (remember, you can only change ReWire settings when Bidule is in standalone mode)
-Here's the Bidule DSP settings:
It's funny.....I've had a bunch of Giga patches that I use daily on my Giga pc that I've been avoiding reprogramming in K2 because I didn't feel like going through the pain.....Bidule has inspired me and I've spent the last week reprogramming them into K2. They had lots of layers and Giga's iMidi rules, so it was a pain to do it (hehe I was right to avoid it). Anyway, now that I have them in K2 programmed properly and hosted inside Bidule, I can get more notes out of K2/Bidule than I could with the Giga. I'm sitting here shaking my head. Most of the other Giga patches have simpler programming and load up no problem in K2 without much if any reprogramming needed. Plus, I'm getting the re-released K2 version of SAM brass and the K2 version of True Strike 1. True Strike 2 is already a multi-format installer, so I'll just reinstall that as K2 format. And that's most of the patches that sit on the Giga. Everything else on there can be dealt with on a case by case basis.
The beauty in all this is that I can leave all the Giga stuff intact if I have to go back to old sessions.
Here's something of a more realistic torture test I just did tonight with DP and Bidule with some of the patches I just reprogrammed: I played this in live without any fixes, so forgive the sloppiness. It's more than 10 patches playing simultaneously inside three instances of K2 inside Bidule all ReWired back into DP and then processed in Dp with live DSP plugins. The whole thing is live. These patches have multiple velocities, round robins, K2 scripts, etc. I'm showing the voice counters for all three instances. You can see the combo adds up to over 300 stereo voices during the playback. It's completely clean--no clicks, pops, crackles, etc. (The quality of the audio kinda stinks because Snapz Pro is not the best audio recorder.) Anyway, neither Bidule nor DP seems to be struggling to do this.
http://www.epicscore.com/online/Plogue- ... -notes.mov
I think my next step is to experiment with Bidule/K2 on my Giga PC and see how well it works on PC using the RME 9652 card coming back into the Mac. If it works well, I'll fully ditch Giga, and my life will be one step simpler. (I never really learned how to program efficiently in Giga, so it's always been somewhat of a mystery for me. I'm fairly comfortable messing around in K2, so it makes me feel more at ease to have all my important stuff in K2.)
Cheers.
-gabe
Computer: 2019 Mac Pro 28-core 2.5gHz, OS 10.15.2, 96GB ram, all SSD/NVME drives, MH Labs ULN-8, MOTU MidiTimepiece AV
DP Setup: DP10.11, all Spectrasonics VIs, all Waves plugins, Sonnox AU, Altiverb, NI Komplete 12/K5+6, Plogue Bidule 64 as VI host
