It is currently Sat May 25, 2013 8:27 am
Text Size
Sample rate and buffer size greyed out
Postby elcabong » Tue Oct 07, 2008 2:05 am
I'm using WinXP with the ASIO driver and the sample rate is set to 44.1 and the buffer size is 512 and these values are greyed out in the EK setup screen. My sound card is a TC Electronics Konnect 8 firewire and it is capable of much better performance. I've tried changing the values in the Konnect 8 control panel, but that does not change them in EK's and casues it to become out of synch with my card.. Has anyone else seen this and/or found a workaround? So far no luck from tech support. :evil:
I've noticed that if I select one of the non-ASIO drivers it becomes ungreyed, but those drivers run really poorly on my system and are unusable.
elcabong
Return to Electric Keys (Windows)
Who is online
Users browsing this forum: No registered users and 0 guests
Who is online
In total there are 0 users online :: 0 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
Login Form
