After having moved from G4 1,4Ghz to G4 1,25DP MDD I also cloned the old HD to another newer HD, re-authorized Unisiyn but.... Everytime I attempt to load Unisyn 2.11 it immediately closes.
On my G4 1,25DP runs Mac OSX 10.4.11
What gives... is it perhaps a double processor issue?
TIA
Michele
Unisyn 2.11 and G4 1,25DP MDD
Life without music would be a mistake
MacPro 10core i9 10850K MacBookPro 16" i9 DP11 2 16A 2 828mk3 2 8PRE Ultralite mk5 3 MidiExpress 128
- npatton
Michele,
I'm staring at your post wracking my brain for an answer. This exact thing was happening to me a few years ago on my own MDD, but for the life of me I can't remember how I fixed it. I just wanted to bump this thread and see if anyone has any more ideas.
Shouldn't be a dual processor issue (works fine here on a Sonnet set-up). Might be an Audio/MIDI setup issue (something messing up when you cloned and moved your system). You've re-authorized, so that's not it. Have you tried reinstalling Unisyn completely from your discs? That might be what I did, frankly. Wouldn't take long at all, and your docs shouldn't be affected.
Let us know what happens!
Yours,
n
Yours,
n
Mac Pro (Late 2013) (3.5 GHz 6-Core Intel Xeon E5, 32 GB RAM) OS 10.13.6
MacBook Pro (2 GHz Intel Core i7, 8 gigs RAM); OSX10.11.6; DP 10.13; Unisyn 2.1.1; Stylus RMX; MOTU MIDI Express XT; MOTU 828x; Kurzweil PC3 with Kore 64; Roland XV-5050, D-50; Alesis QS7; Yamaha S90ES, TX-216; Hammond XK-3
FWIW, my own music can be heard at...
http://www.neilpatton.net
http://http://www.pandora.com/neil-patton
Business Site: http://www.pattonmusic.com
A fresh install (Custom – choose only the Unisyn app) and reauth usually cures this. But sometimes the authorisation file gets corrupted and has to be manually removed before a new one will "take."
Kind regards.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
– ideation –
npatton, cuttime and Dave Bourke
I'm simply moved by your kindness and helpfulness
Actually I have some problems with ATA and Serial ATA Hard Discs that - apparently - create some mismatch among them. When I reboot from SATA drives I can see ATA Drives, but I can't boot from them...
In fact I tried to creae a monster G4 with 2 optical drives and 4 Hard Discs, but perhaps something's gone wrong
All in all the configuration is quite complex: 4 discs, several partitions, OS9.2, OSX 10.4.11 and 10.5.xx, all living under the same roof..
It's probably a matter of jumpers... I'm an architect, not a computer technician.
anyway, I'ìll trash Unisyn prefs.. and crossing fingers..
Best regards form Italy-
Michele
Michele
