Ivory piano 1.7 and DP 5.1.1
Hi,
I need a piano library.Do you think the new version of Ivory will
work on DP 5.1.1? I´m using Dual 2.0 PPC with 2,5 ram.
Thanks a lot!
noisetree
Thanks a lot!
noisetree
no reason the think it wouldn't, noisetree.
I would consider getting a dedicated SATA hard drive for it to take advantage of the wider data bus. I would probably be tempted by a smidgeon more RAM as well just to help with the massive amount of page data for all those samples--
12 layers x 88 keys = 1056 samples
x2 for una corda (soft pedal) samples = 2112 minimum total number of samples to be managed at once.
Big-- fast data bus, indeed!
- Eleventh Hour Sound
Ivory is amazing. I think you may have an open SATA slot inside. You could get a cheap 7200 SATA drive ($75) and load the bare drive right in there without even using the LaCie. I would also recommend some memory It's also getting dirt cheap these days $100 for 4 Gigs someone said!
FWI: DP 5.13 is a pretty solid (and free update) and OS 10.4.11 seemed pretty solid at the time too
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars
You can. The more drives the merrier. It works well to have one boot drive, one for sound libraries, one for your DP audio And of course a back up drive
noisetree wrote:Thanks for your replies.
I´m going to get 4G more.
Why can´t I use my Lacie quadra?(firewire 400 and 800)
noisetree
- KarlSutton
I use ivory on a 400FW drive & can play at 128 buffer on my G5 dual 1.8 w/4GB RAMnoisetree wrote:Thanks for your replies.
noisetree
MPB 17" 2.66 i7/8GB RAM, OSX 10.6.8, DP 7.24, 828 mkII, Ethno 1 via Ultimate Soundbank, MX4, MSI, Komplete 9, Ivory, Stylus RMX.
for a time:MacPro6,1 3Ghz 8 core 32GB RAM
Cool. Yeah, you can have your Ivory library on the LaCie.
But I am so sad!
Last week I ordered Edition Beurmann Grand Piano for a project that I´m working.
Sounds big with a little pink noises but the big issue is a tunnig problem.
I know that this piano is from 1847 and is tuned at 435Hz but I read that was presets in 440Hz.
No matter what this piano seems always out of tune.I tried to tune it manualy in Kontakt but for me it didn´t work at all.
Anyway two days ago I ordered Ivory at...an online store(not going to tell you because I don´t want to be unpleasant)
where there was information that delivery time was at once.I paid and wait two days for some feedback.
Today I ask them why I was waiting so much for some info.They told me that after all there isn´t Ivory in stock...
"maybe at the end of the week or beginning of next week" was the phrase that killed my day.
I refuse to get plugins with piracy but now I´m so desperate.However I´m not going to change my principles.
I´m stuck!...
Thanks for listening.
noisetree
I´m stuck!...
noisetree
Can you cancel your order and go to somewhere like Guitar Center? Most people should have it in stock. Reason's got a pretty reason-able piano if you have it and need to make due...
Ivory is like 40 gigs... It's a big Moma. Some guys here like The Pianoteq piano. You could probably buy that online and download it since it's really small. www.PianoTeq.com They have a free demo you can try.
I wouldn't hesitate to cancel an order if they misrepresented their inventory.
noisetree wrote:I want this big Moma!
And I hate the word cancel.I try to avoid that "action".
But I think I´m gonna try pianoteq.
I´m in Europe.
noisetree
