GUI is only displaying the left side!!! HELP!!
I just bought this software and after hours of figuring out that i had to copy the samples to program files/motu/vst/sounds.....i have the sounds working, but only the left 3/4 of the GUI is displayed. Im running this on a PC with 4 gig of ram and 2.4 Ghz dual core.
Re: GUI is only displaying the left side!!! HELP!!
What host are you using?drdrawbar wrote:I just bought this software and after hours of figuring out that i had to copy the samples to program files/motu/vst/sounds.....i have the sounds working, but only the left 3/4 of the GUI is displayed. Im running this on a PC with 4 gig of ram and 2.4 Ghz dual core.
DP 5.1, Ableton Live 6 Beta, Cubase, Absynth 3, BFD, Ivory, Cameleon, Tassman, Dimension Pro, Rapture, Kontakt 2, Minimoog V, Reason 3, Reaktor 5, Mac Pro, Trigger Finger, Axiom 25, Axiom 49
Re: What host
I have Cubase 4 on my PC, I'll see if it does the same thing for me...drdrawbar wrote:Cubase primarily, but it does it as a standalone as well.
Re: Thank You
Yeah, the installation routine for the Mac was dead wrong, and my tech support form is still "unread"...drdrawbar wrote:I cant tell you how much i apreciate it. I have a tech note in to motu, but who knows how long that will take to get an answer.
Trying right now.
Re: Thank You
I can get the standalone to come up in Vista and work ok, but Cubase doesn't recognize the plugin at all on the PC. On the Mac, it's ok...
-- what version of Cubase are you on? Which OS?
one thing you might try in preferences is to turn off the autohide of the VST
plugins in the VST window, and maybe also turn off the setting to turn off
the plugin when there is no audio (even though I think EKeys is VST 2.x)
-- still playing around here...
This may be caused by incompatible graphics hardware. What kind of graphics card is installed in your machine? I think MOTU's recent VIs (MSI, Ethno, MachFive 2, and EK) require certain OpenGL support from the graphics hardware that some older cards can't provide.drdrawbar wrote:I just bought this software and after hours of figuring out that i had to copy the samples to program files/motu/vst/sounds.....i have the sounds working, but only the left 3/4 of the GUI is displayed. Im running this on a PC with 4 gig of ram and 2.4 Ghz dual core.
That's an interesting thought.. what happens when you click the1nput0utput wrote:This may be caused by incompatible graphics hardware. What kind of graphics card is installed in your machine? I think MOTU's recent VIs (MSI, Ethno, MachFive 2, and EK) require certain OpenGL support from the graphics hardware that some older cards can't provide.drdrawbar wrote:I just bought this software and after hours of figuring out that i had to copy the samples to program files/motu/vst/sounds.....i have the sounds working, but only the left 3/4 of the GUI is displayed. Im running this on a PC with 4 gig of ram and 2.4 Ghz dual core.
"effects" button? Does another window pop up?
Re: Cubase/EK
That definitely sounds like a coding bug.... I don't have XP so I can't test your exact situation... have you heard from other folks?drdrawbar wrote:When i open the FX window, it pops up. but also only displays half of the GUI. I have recently found that minimizing the standalone and then maximizing it it displays correctly. Im using XP pro.
