Crackling audio? Try CoreAudio Aggregate Devices.
- croyal
Re: Crackling audio? Try CoreAudio Aggregate Devices.
Thanks Sooshie and Qo.
I just moved up to the G5 and today started getting spikes and crackles only when auditioning soundbites in the editor. I have only one interface- but it is indeed from Apogee.
Needless to say- after creating Aggrigate device and reconfig of Audio Bundles- all works flawlessly- even with buffer at 128!!!.
Great detective work, you two!!!
Chris
Chris
Mac Studio Ultra/ 2013 Trashcan. DP10 and 11.
32 channels of Apogee Symphony MkII/ Dangerous 2Bus+.
Lots of Neve, API, and Dangerous outboard gear.
I'm having the same problems. I have a Firewire Solo as well. I'm trying to use this trick but after I click on Audio Devices I see no Menu to choose aggregate devices. Where is it? Thanks.
Brandon
Brandon
- qo
Excellent Chris! I'm so happy this is working for others. After weeks and weeks of this problem, I'm still a bit paranoid about hearing a crackle but so far (knock, knock) it's all been golden.Originally posted by Croyal:
Thanks for that azusa! Sometimes trying totally off-the-wall insane stuff works. Not often. Just often enough to keep trying All the other stuff I've tried that didn't work is too embarrassing to mentionOriginally posted by azusa:
Wow!! This is the coolest trick of the year.
Great job qo.
- qo
Hi Brandon,Originally posted by guitarbth:
It should be under the Audio menu in Audio/MIDI Setup's main menu bar (just to the right of the Apple menu). There's a keyboard shortcut for it: Shift+Apple+A
Let us know if that doesn't work, OK?
Still no luck. But I think I figured it out. I'm not using Tiger which I believe is when the Aggregate Device was introduced. Correct?
Thanks.
Brandon
Thanks.
Brandon
- Shooshie
Yes, Brandon. Unfortunately for some, this is a Tiger-only feature. I remembered that being a feature of Tiger, allowing multiple audio interfaces for all comers. That's how they did it; they created the aggregate device, which DAWs see as only one device. It's very interesting to me that Core Audio can see the interfaces, combine them, and present them to Digital Performer in a form that it is very happy with, when DP itself could not do that.Originally posted by guitarbth:
Thanks.
Brandon
Such is technology. Thank goodness it keeps getting "better." Now you have one more reason to upgrade to Tiger.
- Shooshie
Don't be. That article in Sound on Sound described this in great detail, and I am confident that we've found the Yellow Brick Road again. So, don't worry; be happy. We're off to see the wizard! (curse those flying monkeys!)Originally posted by qo:
After weeks and weeks of this problem, I'm still a bit paranoid about hearing a crackle...
Well, even though I don't have Tiger and cant use the aggregate device trick I was able to get rid of the distortion I was experiencing by removing an instrument track that I was playing along with....
Brandon
Brandon
- qo
Yes, one thing to note is that what we are discussing is a solution to a problem that is independent of CPU utilization. The crackles occur when CPU is almost idle.
In your case, it sounds like the CPU is the issue. You can display CPU usage using Studio->Audio Performance
I still get pops if I max out the CPU in DP using VI's. But, this is expected behavior and correlates exactly with the CPU meter maxing out.
EDIT: Corrected the menu item reference above now that I'm home
<small>[ August 05, 2005, 10:04 PM: Message edited by: qo ]</small>
Qo, you are a saint and a savior! You can really die happy given your contribution to the audio community at large. With my firefaces, the difference is huge. On a large session, I get way less dropouts, timing issues, just a lot less flinching in general. Great work!
- qo
Wow, thank you thermos! I think I now understand how Sally Fields felt at the Oscars when she said "You do love me!" (OK, I've just dated myself, heh).
Hi.
I used Aggregate Devices to solve the exact same click/pops as described by Qo and Shooshie. That was great.
However, I couldn't get a movie to play in DP while the Aggregate Device was the active device. As soon as I unselected the Aggregate Device and then did it the old way of selecting both devices, the problem went away.........bummer.....I started another thread with the movie problem before I realized what the "fix" was.......
Anyone else seeing this?
My interfaces are a Mobile IO and (2)x2408's.
Thanks.
-gabe
Thanks.
-gabe
Computer: 2019 Mac Pro 28-core 2.5gHz, OS 10.15.2, 96GB ram, all SSD/NVME drives, MH Labs ULN-8, MOTU MidiTimepiece AV
DP Setup: DP10.11, all Spectrasonics VIs, all Waves plugins, Sonnox AU, Altiverb, NI Komplete 12/K5+6, Plogue Bidule 64 as VI host
- Shooshie
Oh dear. For every solution for a given problem, there exists an opposite and equal problem along the same straight line. I hope that's fixable. I'm not working with a movie at the moment. Maybe someone else will tackle it. If it's a problem, we should report it to MOTU... er... after we convince them that there was a problem beforehand, and that qo solved it!
"Moof," said the dogcow.
I reported this crackling issue at NAMM....to a senior tech guy....he was very nice, but had never heard of the problem.
The problem didn't exist in 4.12 for me. It appeared in 4.5 and has been there ever since.
When I saw qo's post a couple weeks ago and finally upgraded to Tiger, VOILA! problem fixed. That was so great!
Then, I opened a move last night and then bang.....problems again...but this time different.....argh.....
I'm gonna call MOTU on Monday.....
Thanks.
-gabe
Thanks.
-gabe
Well... Looks like I'll be getting Tiger tomorrow. Notime bettter than now I guess. Thanks for your help qo.
I'm not really a smartass..... However....I did stay at a Holiday Inn Select last night.
