Demo Music
This forum is where you can post links to sound files of your projects created in Digital Performer in order to get feedback. You may also plug your band and announce live performances.
Demo Music
This is a piece of music going into my demo. Let me know what needs work.
http://www.marcussjohnson.com/mp3s/Film ... Change.mp3
Thanks,
Marcus
Thanks,
Marcus
- airtime
Something's wrong with your upload, marcushane, I get intermittent playback.
Wayne
Wayne
iMac11,1, 2.66 GHz, 8 GBRAM, OS 10.6.8, DP 7.24, MOTU 828mkII (BLA clock & analog mods), VoiceMaster Platinum, RNP preamps, 4 handmade mic pres, AKG C451E (vintage), AKG 460B, AT 4050, Red/Oktava, sE Z5600A, Shure 545 Unidyne III, Sennheiser MD21s, a few cobbled electret mics, Genelec 1030As, SVS subwoofer and a room that's honest if you're in the sweet spot.
Your right Wayne it's completely F*ed. I though it was because of a bad connection on my side. How do I fix that? A smaller kbps?
http://www.marcussjohnson.com/Channel%20Change.mp3
So I cut it down to 128 kbps, but now there are serious artifacts pumping in the audio. Does anyone have experience with this?
Thanks,
Marcus
Thanks,
Marcus
What program did you use to upload the file. Make sure it was uploaded in binary rather than ASCII. Generally that's automatic now, but I've heard this happen when audio is uploaded in ASCII mode.
James, That would make sense. I'm using Cyberduck. I switched it to ASCII not to long ago for something.
That looks like it did the trick. Let me know if it works. I'm retarded.
Thanks,
Marcus
Thanks,
Marcus
- killerpineapple
It's an intimate and nostalgic kinda piece but I have some suggestions. The piano and the percussion sound very robotic, which seems to defeat the mood of the piece. Maybe mess around with note velocities, tempo, and add some randomness to the quantizing.
I also felt the piece deserved some sort of over-the-top climax. I like the way the piece grows, but I would have been happier with more...
...But then again I'm not sure what this is a demo for.
- Matt
G5 dual 2.7 GHz PPC, OSX 10.5, DP 5.13, MOTU 2408 mkII, PCI-X 424, MSI, Roland 2080, EWQLSO Platinum Pro, EWQLSC
i like the robotic quality myself! you could easily extend the piece a little, and add an instrument in the lower registers. it's a little bit thin sounding, which is OK, if that's what you are going for. Maybe experiment with panning to widen it a bit. But it's a cool composition, would work well in TV and film.
why would i want to skin a cat?
