Homestudio
Homestudio
Hi there,
I would like to setup my new homestudio. MOTU 8282mkII should be at heart of it. Could you please review following images and let me know, if I my imagination went too far, or is everyrthing as it should be?
Thanks a lot
Dalibor
Thanks a lot
Dalibor
- Dwetmaster
Everything seems to be workable. My only advice would be for you to get a MIDI interface instead of sending your MIDI signal thru everything. You can get a MIDI express for not too much...
My two cents
My two cents
- Dwetmaster
Yeah, that way, you can route everything separately to the computer and, with the proper driver files, control your devices easily from your Computer.BradLyons wrote:simplicity, that's the reason.
You can make dedicated automation MIDI track in your sequencer and assign these tracks to the right device without worrying about another one getting screwed up by undesired MIDI information.
If the Yamaha MO6 has USB like the Motif, use USB for your MIDI to and from the Yamaha, then use the MO6 MIDI out to drive your FX. You never need more than one MIDI channel for an FX box, so daisy chaining is just fine unless you have more than 16 devices. Properly set up in Audio>MIDI Set up, things work great!
One thing to watch for when using Yamaha USB is ground loops. I had to make a special USB cable by cutting the shield and ground conductor mid-cable to silence my setup. Here's my post on the subject:
Had a nasty buzz. No drugs involved. Dim the lights, set the mood, there's that buzz again. What's up?
I've always noticed my Motif ES is sensitive to grounding. Tried all the usual things: Plugging all devices from one outlet, cutting ground wires on audio connections, even lifting the ground on the Motif and other devices' AC. But still, a subtle ungood buzz remained, robbing delicate mix moments of transparency.
Turns out that a potential exsts between my MOTU 828mkII Firewire ground and the Motif ES USB ground. Fixing it was simple: cut and pull back the plastic sheath on the Motif USB cable, remove a short section of shield and cut the black (USB gound) wire, one of four within the USB cable. Viola! Dead Quiet.
I mention this as an FYI, something to file in the back of the mind. The black wire in a properly-wired USB cable carries the ground, and can be removed as long as there is an alternate path to ground, like through an audio cable or AC grounding. Now, I am going to re-mix the tune I am working on, free from inharmonious grunge. I'm feeling good, riding a no-buzz high!
HC Markus
CueMix can route 4 buses to whichever outs you desire.
Cubase can also has multiple assignable buses. Or you can create group channels, assign any tracks to them, and assign the group track to any output.
MOTU 828mkII, MOTU 8PRE, Cubase Elements 7, Win7 64bit, Yamaha Motif ES8, Virus TI, Casio Privia PX-350M.
