It is currently Wed May 22, 2013 3:10 am
Text Size
Affordable phono preamps for vinyl restoration?
Postby resolectric » Thu Nov 01, 2007 1:48 pm
mhschmieder wrote:Didn't Adobe Audition get a bad review recently for its restoration stuff; in particular its denoising component? Maybe that was here in this forum on one of the audio restoration topics vs. in a magazine. ...
That's quite natural.
Everything gets bad reviews every now and then.
If it fits the bill i'll give it a good review then.
Why?
Because i know how to use it's denoising component, wich, by the way, is awesome.
Adobe Audition = 5 stars.
resolectric
Postby mhschmieder » Thu Nov 01, 2007 2:08 pm
Is it available for the Mac? Adobe has gone back and forth with some of its apps over the past few years. I think Premiere was the one that went Windows-only but is now back on the Mac?
MacPro Quad-Core Intel Xeon (2.8 GHz, 16 GB), OSX 10.6.8, MOTU DP 7.24, BIAS Peak Pro 7.0.1, DSP-Quattro 4.2.2, iZotope RX 2.1.0, Melodyne 3.2.2.2
RME FireFace UFX, Focusrite OctoPre Mk II, True Precision 8, AEA RPQ, Radial PZ-DI, Radial Reamp JCR
Eugenio Upright, Dingwall Afterburner, Yamaha BB-1025X, 60th Ann P-Bass, Fender Select J-Bass, Reverse Jaguar Bass, Gretsch Jet Baritone
Yamaha WX5, Hammond 44 Melodion, Hammond XK-3c, Minimoog Voyager, DSI Prophet '08, DSI Evolver
mhschmieder
Postby wvandyck » Thu Nov 01, 2007 3:48 pm
airtime wrote:As an experiment I dragged out my 27 year-old Technics SL-1800 turntable with Shure M95ED cartridge and connected the outputs to the fully turned up Mic/Guitar preamp inputs on my 828Mk2 (BLA mods) with no RIAA preamp in the chain. I recorded some tunes from a Missing Persons LP that printed at about -12 to -18 dBfs and sounded thin and tinny, as expected. Then I inserted an instance of the MOTU 2 band Parametric EQ and dialed in an approximation of the RIAA eq curve as compared with a version of the curve I found on a website. The result? Surprisingly good, although still lacking in overall gain. Adding 20dB of gain with a Trim insert after the Parametric EQ made it all good. If i knew how to attach an image to this post I'd show you the parametric settings.
No RIAA phono preamp is needed at all!
Wayne[/img]
Thanks for posting this.
I had given some thought to trying this out given the types of plug-ins at my disposal.
Right now there are many options to go with, and I'm not really which is the best for my intended use.
Your method is definitely priced right :D :D :D
To post an image, it has to be uploaded somewhere on line. You click the Img button, then drag the image from another web page open to the image. Click the Img button again. Result below.
You could PM me so you could attach the image to an email. Then I'll post it here.
"Every picture tells a story doughnut"
What were the Small Faces really saying?
http://dl.dropbox.com/u/20203707/Audio/DP/MOTU.pdf
The Evolution of DP: A Loose Timeline
http://dl.dropbox.com/u/20203707/Audio/DP/Evolution_Of_DP_2008.pdf
wvandyck
Postby mhschmieder » Thu Nov 01, 2007 4:27 pm
I just looked up the latest release of Adobe Audtion and it's still Windows-only, but only costs $349.
Several people on the KVR forum seem to prefer it to RX in terms of bang-for-buck, when ignoring the recent $199 promotional.
RX is still adding features and documentation.
If you go an all-software approach, be careful which order you apply the gain and the RIAA inverse EQ.
mhschmieder
Postby wvandyck » Thu Nov 01, 2007 5:41 pm
mhschmieder wrote:If you go an all-software approach, be careful which order you apply the gain and the RIAA inverse EQ.
Can you be more specific about this?
A software approach may be the answer for the time being.
This thread has exposed me to some options I hadn't considered before: Audacity, the Gram Amp 2 SE (and Gram Amp 1), and the Denon DP-DJ150.
The dilema is that I'm not seeking out 'new' vinyl at this point. There are about 400 pieces available here at the house and my wife's parents home close by. I'm not sure how far I plan to go with vinyl restoration. Obtaining RX was a no-brainer. It's quite possible in time I may go with a Gram Amp to complement my current turntable, or go with a new turntable with a built-in preamp compatible with 78s and all the necessary connectivity options. So until I'm very clear on my plans, the less spent the better.
This has really been an informative thread with many new bookmarks as a result.
wvandyck
Postby wvandyck » Thu Nov 01, 2007 6:43 pm
So here's airtimes rendition of the RIAA curve:
wvandyck
Postby airtime » Thu Nov 01, 2007 7:30 pm
thanks, flash!
wayne
iMac11,1, 2.66 GHz, 8 GBRAM, OS 10.6.8, DP 7.24, MOTU 828mkII (BLA clock & analog mods), VoiceMaster Platinum, RNP preamps, 4 handmade mic pres, AKG C451E (vintage), AKG 460B, AT 4050, Red/Oktava, sE Z5600A, Shure 545 Unidyne III, Sennheiser MD21s, a few cobbled electret mics, Genelec 1030As, SVS subwoofer and a room that's honest if you're in the sweet spot.
airtime
Postby airtime » Thu Nov 01, 2007 7:43 pm
perhaps that's RIAA with a bit of IEC enhancement, eh?
airtime
Postby mhschmieder » Thu Nov 01, 2007 7:50 pm
Feel free to extract and wordsmith my PM's once you have a bit more clarity on your approach. It might prove useful to others, but I didn't want to sidetrack the topic once it switched over to talking about the software plug-ins.
mhschmieder
Postby wvandyck » Thu Nov 01, 2007 8:38 pm
mhschmieder wrote:Feel free to extract and wordsmith my PM's once you have a bit more clarity on your approach. It might prove useful to others, but I didn't want to sidetrack the topic once it switched over to talking about the software plug-ins.
I'll do that. You offered some very valuable points and information to consider.
wvandyck
Postby wvandyck » Thu Nov 01, 2007 8:44 pm
wvandyck
Postby airtime » Thu Nov 01, 2007 8:52 pm
i'm totally EQed. not to mention phase shifted. it feels so . . .
airtime
Postby vier-personen » Fri Nov 02, 2007 1:57 am
I didn‘t read the whole thread so I might be OT already, but I recently bought this fairly cheap phono preamp (70•‚¬), and I am satisfied with it:
http://www.project-audio.com/main.php?p ... es&lang=en
DP 5.12/OS X 10.4.9/MacBook C2D 2.0 1GB Ram/RME Fireface 400
vier-personen
Postby Phil O » Fri Nov 02, 2007 7:49 am
flashgerkin wrote:Light Reading. (Yeah right!)
Good stuff! Thanks for the links.
DP 7.24, Mac Pro 2.66 quad (6 Gig RAM), Mac Pro 2.8 octo, (12 Gig RAM), OS 10.6.8, two MOTU 828s, Apogee Rosetta 800, UAD-1e, UAD-2, a whole truckload of outboard gear and plug-ins, and a partridge in a pear tree.
Phil O
Postby wvandyck » Fri Nov 02, 2007 1:34 pm
airtime wrote:i'm totally EQed. not to mention phase shifted. it feels so . . .
I thought I might come across an easy to read chart from which to plot the curve. No such luck.
You actually nailed it down very well.
wvandyck
PreviousNext
Return to General Recording
Who is online
Users browsing this forum: Google [Bot] and 0 guests
Who is online
In total there is 1 user online :: 1 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
Login Form
