When I open up DP5 I get the message "MOTU Symphonic Instrument, Continue/Quit"
"This Version of MOTU Symphonic Instrument requires authorization again in order for you to continue using it. Please press the "Continue" button to begin the requthorization process."
I'm not using SI anymore, even pulled the usb key out, but still get this message. I can just select Quit to continue, but I'd rather not have to do this every time I open the program.
I'll probably want to use SI again someday, but not now. Checked the SI manual which said to check the DP manual -- but SI is not even listed in the index.
What do I need to do to get rid of this message from DP5 bootup?
Fred
How can I turn off SI "Authorization" screen...
