Ok... 1st timer so get u'r gunz out..
Problem. No audio out from monitors.
Just got new Ableton Live, Remote SL, Ultralite set-up.... all installed with new updates, new drivers, all good me thinks.
However, No audio out from monitors. Only on headphones. Checked the channel config. in Live (Chan. 11/12), correct MOTU Audio ASIO as audio device and type. All good.
The funny thing is that when I enable the test tone within Live, it comes out through both monitors. Great... it works but.....
When I press a key, audio is registered on Live, the phones output on CueMix (Not main outs) and thru the headphones only. However Ultralite does not show that audio is coming in/out.
Running XP with good specs.... but with a NEC firewire chipset. NOW IS THIS ISSUE? I just want to know before I go out and get myself a Texas Inst. chipset that MOTU recommends. I've done the firewire speed fix too.
I havn't fooled around with CueMix, just snooped around to see if i can fix the problem there.
It just seems I'm so close to sorting it out, that I reckon it could be just a simple fix. Posted in Ableton forum too, I've been reading too many forums it's done my head in.......
Come and save me!!!
Tell me where I'm at....
- Atardecer
I guess one thing to check is the channel config in Live's preferences. I remember trying for ages to find the Mic 1 & 2 inputs from my 828 MKII in Ableton, only to realise that they come up as inputs 9 & 10. But youre talking outputs here. Hmmm, if you're getting test tone thru the monitors then you can rule out any air gaps there. I would definately check your cuemix settings. Chances are you are monitoring and bussing everything to your headphone mix but nowhere else.
Cheers,
James
Cheers,
James
James O.
www.myspace.com/fixederror
