I have the Motu traveler.
Mac OSX 10.4.8, Power PC G5.
Traveler:
Firmware 1.07
Bootloader 1.01
Driver 1.4.2
I use DP 5.11
About 60% of the time I don't get any audio signal
to my monitors, I can see the signal is coming in from
DP on the Traveler display (Analog out) but I don't
hear anything in the monitors. I shut it down and turn
it back on (the Traveler) and sometimes it works on the first try,
sometimes it takes a few.
Another problem, I can only get mic/instrument input
number 1 to work, if I plug into the other three nothing happens.
Yes I have checked the gain and volume, number 1 is the only
one that works.
A few days ago I started getting static sounds in my speakers
when Traveler finally works, just loud static noise that comes and goes.
I think my Traveler is broken, any great ideas out there ?
Thanks.
Traveler problems !
Hello Guys, I'm having a bigger issue with outputs.. no signal at all:
I've recently purchased a brand new MOTU Traveler, I've done all the connection right, but, even if I can see input signals on its analog LED meters, output LEDs are definitely off and no audio is audible in all the outputs (with or without firewire connection). There's no mute, levels are up and I've tried with all the output configs.
And I've forgot to mention that even trying with computer connection (iMac Intel Core Duo) with CueMix Console I can't select any output: I can read "output disabled" on its selecting button, and even if I choose any other output from its pop-up menu, it returns always on "output disabled"!
I've already tryied to disinstall and reinstall all the software...
What else can I do?
Thanks for any help!
What else can I do?
