I recently upgraded to OS 10.4.9 DP 5.11 runs great. I am finally getting back to my hardware synths and having trouble with my unisyn installation. About 2/3rds of the way through an error comes up "1008:5,-5000 access denied error". This sounds like a mac permissions problem, so I ran disk utility and fixed permisions with the same result. So then I connected my back up hard drive from system 3.9 and copied the unisyn folder over. Now I can start Unisyn but I can't get past the authorization window. I enter my name and the keycode from the manual. I click ok button and the authorization window returns with blank fields. Finally I started up in 10.3.9 and verified that unisyn runs fine in that system. Does anyone have any thoughts about what to try next?
Stephen
install error ???
install error ???
Mac OS X version 10.5.8 / DP 7.12 / Dual 1.25 GHz G4 2GB DDR SDRAM / MOTU 2408mk3 / Powerbook G4 / traveler
Re: install error ???
I am not understanding why this thread popped up in my email today. It is an old thread that has since been resolved by mucking around with the terminal. It is a permissions problem and you have to delete the record of the original invisible install file. If someone is having a problem with this I will look up the exact procedure. Once the install record is deleted everything worked as it was supposed to.
The problem exists here with different OS and NEW Unisyn Installation: We got a brand new version of Unisyn donated for our handicapped nonprofit org by the german Distributor KLEMM-Music. System is latest MacOS 10.6.3. when launching the program ist asks for the installer CD, when I put it in and fill in the key, the dialogue disappears, but comes back immediately empty. I've read all support docs, repaired permissions, tried to install and auhorize as root user, all without success. KLEMM couldn't help. There was no invisible AuthUnisyn file to delete!!! So please help anybody!
This may or may not help, but it might be worth taking a look at:
http://www.motunation.com/forum/viewtop ... 10&t=42027" onclick="window.open(this.href);return false;
