Mac Pro doesn't recognize MIDI interface
I have a new Mac Pro (Dual-Core Intel Xeon), OS 10.4.7. Digital Performer 5.1 seems to be fine, except that it can't seem to recognize my MIDI interface (Express XT). I've downloaded the only update available from MOTU. Any suggestions?
look at the bottom of your express xt. if you don't see a sticker with "M/W" near the serial number, then you need to email tech support. you have an older interface and probably need to order a ROM upgrade chip. they go for about $20, available at:
https://www.motu.com/store_products/har ... idiexpress
the mac pro uses intel chips, and so you'll need the ROM upgrade that makes the older mac-only express xt compatible with windows/intel chipsets.
- Dwetmaster
Fmmore.
Can you tell what version of the rom you had? How do you put it in? Is it software or hardware?
the upgrade is done by opening the case and replacing 2 small socketed chips on the main board. it's a 10 minute job from power off to power on for someone that has never opened a piece of hardware before.Dwetmaster wrote:Fmmore.
interestingly enough, i had to revert the main rom chip to the original version as the new one i received was causing strange display issues on my MTP AV. both the old and new main rom chips had the same version number on them, so i guess it didn't really matter. the usb rom chip was the only one with the newer version, and that's the only one i ended up changing. seems to be working fine now.
Dwetmaster,
As eixb says, it's a very simple procedure. Before you remove the older chips, be sure to note the "U shaped notch" at one end. That will keep you from putting the new chips in backwards. It took more time to unplug and then replug my MIDI cables than it did to put the new chips in.
Good luck,
fmmoore
Good luck,
fmmoore
