DSP-Quatro questions-Help needed!
- Timeline
I have been doing DP remixes to DSPQ at 192-24bit and trying to master and create a cd on 15 songs.
I got to the end of the peq list with all the plugs working and set and tried to cut a disk and an error came up saying you needed to lower the sample rate yet the heading on the pull down menu was to create a 44.1 disk image from files. I tried this some time ago at 96K-24 and I remember being able to cut the disk but now I'm stopped in my tracks. Please confirm this works, anyone???
If there is a workaround without conversion this is what I'm looking for. Replies from DSP-Q do not come and its been several days so any help here would be welcomed.
On other thing. I wish the MOTU plugs worked as AUs in this app. I love allot of them.
Regards,
Gary B
Regards,
Gary B
- Timeline
Re: DSP-Quatro questions-Help needed!
I tried to add a couple of tracks and it ruined the entire list and I had to start over. The cue points are not there when moved. It seems you have to build the entire project in the proper order or problems with the green cue points change.
Also al files have to be the same SR or it will not work either. I'm really used to DP auto converting I guess.
It looks like support dropped off the planet. No update since last year and they don't answer emil questions either.
Just FYI, I had a problem with authorization two or three weeks ago and Stefano replied promptly.Timeline wrote:It looks like support dropped off the planet. No update since last year and they don't answer emil questions either.
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 14.1.2
MacBook Pro (15-inch, Mid 2012) - 2.6 GHz Intel Core i7 - 16 GB RAM - macOS 10.15.7
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
- Timeline
I'll try him again, Thanks
Is there a possibility that one of your plugs does not like the sample rate conversion?
- Timeline
Hi Mike. No, I got through that. My problems are now all around the region lists. The sound files are all there but the markers are all screwed up. I'm trying to find a way to rebuild the entire markers list at this point so I can reset the cue start points. I never used this app really although I bought it last year. I generally just used toast before that but the features with the plugs sound better in Stafanos program. I have tried everything and so far I cannot get things right unless I start over completely with new files clean. I have converted everything to 44.1 for now but was hoping to do everything 192 and then cut a redbook CD final. I have 16 tracks. Basically all the songs I have recorded over the last 10 years I was planning to put up on Apple streaming.
