No sir. DP allows you to route specific MIDI ports to specific MIDI tracks for recording directly. Logic does not. All MIDI recording has to funnel through a single internal virtual MIDI port in Logic to get to the recording tracks. And worse yet, Logic has the failover method where if MIDI data is not accounted for by any of the record-armed tracks, the currently selected track will get it, even though you don't want it to. Alternatively, in DP if you don't explicitly assign a MIDI port to a MIDI track, then that MIDI will be ignored by DP. DP is much more explicit, clear, concise and predictable.Michael Canavan wrote: the truth is all MIDI data enters into the computer as a single stream, Logic just exposes that.
Its usually workable with some nutty environment stuff, but DP's approach is just way cleaner and explicit, handles large MIDI setups much much better. Logic works fine for a simple setup with one or two keyboards and without plugins that produce MIDI output, but as soon as you start tinkering with more elaborate MIDI routing, Logic turns into a headache and its hard to sometimes figure out what its doing because it has a lot of implicit behavior like I just described.
Yea man I agree, Logic blew it on that aspect, that's why I pointed it out. But nonetheless, the MIDIFX provided by Logic and 3rd parties is way way superior to the couple of MIDI plugins provided by MOTU in proprietary plugin format. But in DP's defense, it does support VST MIDI output and awesome MIDI routing to handle it, where in Logic's case its required to use IAC to loopback MIDI from plugins back to a track for recording, which also runs into more headaches due to the single sequencer port I mentioned.I disagree about the MIDI FX though, just the fact that in DP you can quickly print them to a MIDI track makes DPs approach
better.
Some simple situations such as keyboard splits and zoning, etc. sure can be handled by Logic. I'm not complaining about that. The environment does have interesting abilities to tweak the MIDI stream. My main gripe with Logic is not the environment, but rather A) that we actually HAVE to mess with the environment for simple situations that should not require it and B) the single pipe into the sequencer and C) no ability to route MIDI output from any plugins to record to a track and D) the implicit nature of how MIDI is taken from that one common sequencer port and directed to various tracks based on implicit and sometimes not very clear behavior rather then explicitly the way DP does it.Multi instrument MIDI recording and MIDI filtering is all quite possible in Logic, the main limitation IMO with the way Logic handles it is that MIDI tracks are all deselected when you select a track without hitting the record button directly... that's a PITA IMO. To be fair though it's super easy to select say two software instrument tracks in Logic and limit their keyboard ranges so you can ply them on the same controller, without having to set that up on the controller, therefore allowing you to have different splits for different songs.
Correct and this is where the single sequencer port becomes a problem. Its not keyboard splits. In Logic you have to find a way to route MIDI from plugins out through IAC and back in through the main sequencer port again to get to a track to record. If you are listening to some plugin produce MIDI and drive a soft instrument while trying to play another instrument with your keyboard...all of the above stuff starts to get weird. You can get it to work, but it usually takes some environment tweaking and not very straightforward thinking.In my opinion this is the most glaring lack MIDI wise that DP has.
Logic cannot route MIDI between AU's whereas DP can route MIDI between VSTs. For me the keyboard splitting issue is not a deal killer, and the MIDI between AU's is,NI Maschine requires it to work well inside a DAW.
Yep, I like the piano roll in Logic way way better. I constantly find myself tweaking with the zoom in DP to try to get it to look better and never feel satisfied.The main point I'm in agreement on though is Logics piano roll, much better, clearer to see the exact placement of notes, and no GUI glitches. Maybe none of you get this, but on my screen in DP at certain zoom settings MIDI notes in the piano roll and parsed MIDI in the Tracks Overview will overlap past their actual length, go out a zoom level and the MIDI fits into the area it's supposed to. Logic's piano roll also lights up the keyboard note you're currently playing instead of following the curser around. I find it much more useful to have it light up the note for those occasions when you're using a Kontakt instrument with a range that doesn't correlate to the piano range.
Anything related to audio or MIDI routing is just simply far far far better in DP then in Logic.Oddly enough considering Logic's supposed placement as a great DAW for dance music, it's not that good at side chaining, whereas DP does this with ease.
