Getting samples off an Alesis QS
SixStringGeek
Re: Getting samples off an Alesis QS
Post by SixStringGeek »
Prime Mover wrote:So will it not run on newer OSes? Is that what I'm hearing? Sounds incredibly useful if there's some way I could get my hands on it.
I have Samplit http://www.cdxtract.com/samplit.php and it works quite well. If there are modulation effects, you can try disabling them to get unmodulated repeatable samples, then this thing will build patches for many common samplers out there, then you go in and recreate the modulation effects. Its a cool program and works well - you can specify the resolution from sampling every single key to every nth key.
DP 8.newest on MacPro 5,1 Dual Hex 3.33GHz 64G Ram, 3TB SSDs.
daniel.sneed
Post by daniel.sneed »
SixStringGeek wrote:[...]I have Samplit http://www.cdxtract.com/samplit.php and it works quite well. If there are modulation effects, you can try disabling them to get unmodulated repeatable samples, then this thing will build patches for many common samplers out there, then you go in and recreate the modulation effects. Its a cool program and works well - you can specify the resolution from sampling every single key to every nth key.
Thanks very much SixStringGeek. SAMPLIT is the one I've seen back in the days, and I was now looking for.
