Question: iZotope RX3 Advanced vs. RX3
I recently upgraded to iZotope RX3, but I've wondered whether the Advanced version is worth the considerable extra price. Frankly, I use Waves noise removers more than anything else, but it looked like RX3 might offer more. Waves' Z-Noise is pretty darned amazing, following noise that changes and dynamically adjusting its effects on the targeted audio. I haven't even used RX3 yet, so I don't know how limited it is. But the question is whether anyone thinks I'm going to be disappointed without the Advanced features.
Anyone here used both?
Re: Question: iZotope RX3 Advanced vs. RX3
Yes.
The automated settings are fine in RX 3 but, if you are going to clean up old audio, you might like the manual override of many of the settings. I do. Whether the extra tools (azimuth, Insight, de-reverb etc.) are of any use, I can't say.
I expect that the bread and butter settings of de-noise, de-hum and de-click plus Spectral Repair are what most users use.
I thought the upgrade to Advanced was worthwhile. I also found a project to charge it to - really noisy, crappy audio with hum, click, pop...
That's a $499 upgrade according to my email. No? That's a bit steep for something that can pretty much be handled by Waves and even the lower level RX3. Of course if you have more demanding projects that can justify it, it's probably worth it, but as I don't do much restoration I passed on the upgrade - especially at $4-effing-99!
2013 Mac Pro 32GB RAM
MIDI Life Crisis wrote:That's a $499 upgrade according to my email. No? That's a bit steep for something that can pretty much be handled by Waves and even the lower level RX3. Of course if you have more demanding projects that can justify it, it's probably worth it, but as I don't do much restoration I passed on the upgrade - especially at $4-effing-99!
$499 is the same upgrade price from Sweetwater.
http://www.sweetwater.com/store/detail/RX3AdvUpRX12/
If you are not cleaning up old tape, vinyl or cassettes, I can't see spending the extra $$$ for Advanced. The stock functionality of RX 3 is quite good.
In my case, turning a garbage cassette into a CD master has brought me a fair amount of work via word of mouth so the money was well spent. RX 3-A was the miracle worker but RX 3 would have gotten me to 90% or more.
Insight is an interesting metering tool but there are a few really nice ones out there. It also comes with Ozone 5 Advanced. I suggested that an RX 3 Advanced add-on at a special price for those who owned Ozone 5 Advanced (or vise-versa) would be a nice idea. I have yet to hear back from Izotope. Anyway, it's no longer my issue, ya know?
On Mavericks, some have had an issue with the Izotope demo screen appearing after authorizing. I noticed this in DP 7.24 only while it was fine in DP 8.
The issue is with the Izotope installer not removing or overwriting properly. Here's the workaround:
Go to Library/Application Support/Izotope/RX 3 (or whichever Izotope program is giving you this grief)
Run the Uninstaller. It will tell you that not everything was removed - actually, you may find that little or nothing was removed.
Click Yes when it asks if you want to see the Log.
When you open the Log, you will see many files that were not deleted. Look for the folders (four if I recall - you will know which ones) and delete those. You will now have removed everything that needed deleting.
Reinstall and Authorize if it asks.
Izotope knows about this but I don't believe it is fixed yet.
mikehalloran wrote:On Mavericks, some have had an issue with the Izotope demo screen appearing after authorizing. I noticed this in DP 7.24 only while it was fine in DP 8.
Go to Library/Application Support/RX 3 (or whichever Izotope program that's giving you grief)
Run the Uninstaller. It will tell you that not everything was removed - actually, nothing was removed.
In the log, you will see many files that were not deleted. Look for the folders (four if I recall - you will know which ones) and delete those. You will now have removed everything that needed deleting.
Thanks, Mike. That's good to know. I haven't even run it yet, other than to see if it boots up, but if I see that happening, I'll know what to do. Much appreciated.
Shoosh
