Actually,I think perhaps you are misunderstanding VBC. Try it on a drum bus or a group bus (guitars, background vocals, etc.). Don't go by the presets entirely...they're all set with about a 1.0db makeup gain, for one thing.philbrown wrote:I'm not trying to argue the rightness or wrongness of either method, but I definitely see the other side too. I just had a project mastered and it changed the instrument relationships within the mix. By mixing into a master comp you can hear it's effect while you're mixing and the mix instrument relationships won't be shifted by adding it later. Both methods make equal sense to me logically.Phil O wrote:I think this is the best explanation I've heard to date. I, too, never mix to compression, EQ, or anything else on the master buss. I've just never been able to voice my reasoning as eloquently and Kubi.Kubi wrote:...because you are essentially mixing into a distorted version of reality...
Phil
As far as VBC specifically, I thought it was literally a "bus compressor" and to me "bus" could mean drum bus, vocal bus, master bus etc. But now that I have it and just browsing through the presets it appears it was only really meant to be "Master bus compressor". The name seems misleading to me, but maybe I'm misunderstanding.
Try dropping the makeup gain back to zero.
I honestly can't imagine anyone not hearing a difference with VBC.Then again, I met a girl 30 years ago at an Oklahoma City gig who, in the course of conversation, said taking acid didn't affect her at all.
But humor aside, the difference VBC makes is really
is apparent to me. It's not a maximizer like FG-X, and you can set it to be subtle or really extreme. I like it more on the subtle side where it just
puts the mix in that sweet spot and I can everything distinctly and in the pocket.
