It is currently Sat Jan 20, 2018 8:17 am
Text Size
The OFFICIAL DP7 Bitching and Moaning Topic
Re: The OFFICIAL DP7 Bitching and Moaning Topic
Postby EMRR » Sun May 01, 2011 8:01 am
Just moved to DP7 from DP6. Am I crazy to want a shortcut button added to the tuner plug, to toggle Input Monitoring Mode? That might actually make it useful in my implementation.
Doug Williams
Tape Op issue 73
DP 8.07.
3.4GHz iMac, OS X.10.5, MOTU 16A and Monitor 8.
2.2GHz 2014 MBP fo remotes and editing.
AlphaTrack controller.
Several tons of analog gear, DP generally used like a tape machine with editing, some processing per track, exporting multitrack to analog world.
EMRR
Postby kassonica » Mon Jul 04, 2011 4:34 am
Well I'm going to bitch and moan about the fact that there is nothing to bitch and moan about in DP7.23......
kassonica
Postby Shooshie » Sun Oct 30, 2011 9:45 am
kassonica wrote:Well I'm going to bitch and moan about the fact that there is nothing to bitch and moan about in DP7.23......
What are they trying to do? Put this lucrative forum out of business? What are we going to do with all our extra time? USE these apps? Curse you, MOTU! You're trying to destroy us! :boohoo:
[with tongue in cheek, of course :koolaid: ]
Shoosh
|l| OS X 10.11.6 |l| DP 9.13 |l| 2.4 GHz 12-Core MacPro Mid-2012 |l| 40GB RAM |l| Mach5.3 |l| Waves 9.x |l| Altiverb |l| Ivory 2 New York Steinway |l| Wallander WIVI 2.30 Winds, Brass, Saxes |l| Garritan Aria |l| VSL 5.3.1 and VSL Pro 2.3.1 |l| Yamaha WX-5 MIDI Wind Controller |l| Roland FC-300 |l|
Postby Crashdown » Mon Nov 07, 2011 10:20 am
Hi Guys,
I'm still a bit angry about DP. when it comes to editing audio... why does the GUI slow down so much when you zoom in at a Soundbite? It just lag's and lag's....
Does DP7.24 not use all the graphic resources available on my MacPro Quad 2.66 intel Xeon?
How can I make this better? Adding RAM? Buying a better Graphic Card?
Help... I'm tired of infinite editing hours... (My wife too, BTW...)
THanks,
Toni
Mac Pro 3.1, 8-Core, Yosemite, DP8.07
Uad-2 Quad, SSL MadiXtreme 64, SSL Alpha-Link Madi AX
Crashdown
Postby Phil O » Mon Nov 07, 2011 10:30 am
Crashdown wrote:... why does the GUI slow down so much when you zoom in at a Soundbite? It just lag's and lag's...
Perhaps it's something in your setup. I'm not seeing that problem, even with heavy track counts. If this is becoming a problem for you, it's time to do some detective work. I'd start with studio settings, take a look at memory and CPU usage with Activity Monitor, and then dig into your VI's and plugins. Perhaps others will chime in with suggestions as well.
Phil
DP 9.02/9.51, Mac Pro 2.66 quad[1,1] (6 Gig RAM), Mac Pro 2.8 octo[3,1], (12 Gig RAM), OS 10.6.8/10.11.6, two MOTU 828s, Apogee Rosetta 800, UAD-1e, UAD-2, a truckload of outboard gear and plug-ins, and a partridge in a pear tree.
Phil O
Postby Crashdown » Mon Nov 07, 2011 12:30 pm
Thank you Phil!
Maybe this has to do with the System:
OSX 10.6.8 SnowLeopard
2 x 2.66 GHz Dual-Core Intel Xeon
5 GB 667 MHz DDR2 FB-DIMM
GFORCE 7300 256MB
SSL MADIXTREME 64
SSL ALPHA LINK
U Think it's time to move to a better CPU? Think More RAM will help? Anyone?
I'm really annoyed by those graphic lag's, with CPU Spikes on the performance meter...
Cheers,
Toni
Crashdown
Postby Phil O » Tue Nov 08, 2011 8:28 am
I'm running the same machine as you with only 1 more Gig of RAM and the same OS. It runs DP just fine. Are you running a lot of VIs or is it mostly audio? I use very little in the VI department. Perhaps that's where you're getting the CPU hit. Buffer settings? Work Quanta, Prime Seconds, Max Work Percent?
My settings:
Work Quanta: 80
Prime Seconds: 3.00
Max Work Percent: 99%
Buffer 1024
Phil
Phil O
Postby Crashdown » Tue Nov 08, 2011 9:07 am
Hi Phil,
thanks again for your concern...
I'm not using any VI's...! On a 40 audio track with 12 subgroups, it just lags when I'm editing audio and zooming in on the sequence editor window...
settings:
Stereo Busses 32
prime sec: 2.50
Work Quanta: 100ms
Max work Percent: 95%
Automatic Plug Latency checked
Pre-fill Buffers checked 0.40 seconds
Pretty much the standart settings... gonna try out your settings and report back.
Cheers,
Toni
Crashdown
Postby toodamnhip » Tue Nov 08, 2011 11:47 am
Shooshie wrote:In my experience, the bugs and crashes that are genuinely a MOTU problem will eventually show up on my system. Pretty much all such problems people have complained about in the past eventually happened while I was using whatever was the current version of DP at the time. Sometimes they happened only once or twice. Other times they happened so often I couldn't get anything done. But those things which were more circumstantial -- something caused by the combination of DP with certain plugins, MIDI drivers, audio drivers, permissions, OSX issues, or whatever -- usually did not happen to me. In some cases they did happen, I was able to locate and fix the conflict, and then they never happened again.
I can't say that DP7 has no bugs or doesn't inherently crash; I can only say that since installing Snow Leopard, with DP 6.02 and DP7, I've had DP open sometimes for days at a time, and almost always open during the day, with a variety of projects ranging from a single piano VI to well over a dozen VIs, often experimenting with new plugins and presets, and so far I have not had a single crash or quit. I realize that many people ARE having massive problems, but I think in the end we will find that this is a circumstantial problem. There have been some probable causes identified, but so far nothing that works for everyone. Apple has acknowledged some problems that it's working on, too. It'll just take time.
My sympathy goes out to those who are having problems but can't find the cause. I know it's frustrating.
You always seem to run so clean and well.
I have to wonder, how much audio do you run?
When I have crashes with VI's and such, I have large amounts of tracks with tons of automation, lots of sub bussing etc..
When you mentioned in your nice report of keeping your system running for days without a crash, it sounds like you're mainly running MIDI and VI.s
If so, I wonder how you'd run with the kind of intensive audio, routing, plug in automation etc...that I and possibly others use?
2 x 3.3GHz Six-Core Intel Xeon-24 Gig 1333 MHz DDR3 Mac
OS 10.10.5
DP 9.02, I loaded DP 9.1 but it was too problematic, MTP AV, 828 mkII
LASS Strings 2.05, East West Pianos, East West Goliath, Spectrasonics Omnispere, Stylus RMX, Waves 9, Drum Core, NI Guitar Rig, Miroslav Philharmonik CE, Antares auto tune 7, entire Nomad Factory tube processor library, Reason 3.05, Izotope Ozone 3-4-5-6, Trash 2 and Spectron, Ivory Piano, VI One, and Toontrack Drums, Addictive Drums...Ocean way Drums,etc
toodamnhip
Postby Alfred Zigoma » Wed Nov 09, 2011 12:49 pm
Crashdown wrote: why does the GUI slow down so much when you zoom in at a Soundbite?
I have the same configuration of a computer and the same problems , seems to me it from - for capacities of a videocard, it is interesting to me why DP is not optimized under old computers . I leave
From position by hot keys and hiding those tracks above which I do not edit at present , I Think to make a upgrade of a videocard or to buy a new Mac Pro
MacPro Quad-Core 2.8 GHZ 16GB RAM OSX 10.10, MacBook Pro 13" 2.4GHz 8GB RAM OSX 10.11, Mac Mini MD388 OSX 10.10
DP 8, SSL MADI AlphaLink MX, UA Apollo, SSL Sigma, PMC Tb2, ATC SCM 20, SSL Alpha VHD Pre, Kemper, Powercore x8, UAD Octo, MC Mix(х2), MC Control, Melodyne, Revoice Pro, RX4, Soundtoys, McDSP, Waves, all Slate, VSL VE Pro, SE, Suite, NI Kontakt 5, Halion 5, MachFive 3, BPM, etc...
Alfred Zigoma
Postby BobK » Wed Nov 09, 2011 1:06 pm
If I were you, I'd get more RAM and see if that helps.
Bob
Mac Pro (Early 2009) 2 x 3.33 GHz 6-Core Xeon, 40GB RAM, OS 10.12.6 || DP 9.5 || Metric Halo ULN-8
BobK
Input Quantize Should Be a Preference
Postby KenNickels » Fri Jan 20, 2012 5:06 pm
Why do I have to enable it every freaking time? I always forget. :evil:
Mac Pro 5,1/3Ghz, 12 core, 64GB Ram, OS 10.12.5, MOTU Audio Express, DP 9.13, Machfive, Eastwest Sample Libraries, Spitfire Albion and Chamber Strings
KenNickels
Postby burn em » Wed Nov 27, 2013 6:19 am
I want a MOTU control surface. Specifically one that can do 8 faders + transport control + encoders. Then banks of 8 faders + encoders. Digital scribal strips and metering would be rad.
Oh sh\t! Did I just say what I thought? nooo no. must have typed it. shi\t!
Forget what I typed / said
:koolaid:
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
burn em
Postby KarlSutton » Wed Nov 27, 2013 8:10 am
This forum seems too good to have "B*tch**g" in the subject lien of any topic.
MPB 17" 2.66 i7/8GB RAM, OSX 10.6.8, DP 7.24, 828 mkII, Ethno 1 via Ultimate Soundbank, MX4, MSI, Komplete 9, Ivory, Stylus RMX.
for a time:MacPro6,1 3Ghz 8 core 32GB RAM
KarlSutton
Postby James Steele » Wed Apr 26, 2017 12:30 pm
KarlSutton wrote:This forum seems too good to have "B*tch**g" in the subject lien of any topic.
Obviously it wasn't? Whaddya want for nuthin'?
JamesSteele.com | Dean Guitars | Facebook | Google+ | Twitter
MacPro5,1 12-Core 3.33, 48GB RAM, macOS 10.12.6, ATI 5770, DP 9.5, MOTU HD192, 24I/O, UAD-2 Duo, Lucid GENx192, HV-3C, Red Type B, Dean guitars, Marshall amps, etc., etc.!
PreviousNext
Return to MOTU Theoretical Discussions, Gripes, Petitions & Off Topic
Who is online
Users browsing this forum: No registered users and 2 guests
Who is online
In total there are 2 users online :: 0 registered, 0 hidden and 2 guests (based on users active over the past 5 minutes)
Login Form
