mx4 demo/ patches keep changing back to number 1
Discussion of all things related to MOTU's powerful MX4 software synthesizer.
larry
Post by larry »
i change the patch and when i play it back it changes to the first default patch, In logic 8
azusa749a
Re: mx4 demo/ patches keep changing back to number 1
Post by azusa749a »
I might be wrong but I think it has to do with Logic sending out the default patch if you don't insert a patch change in MIDI track.
OMNICELL
Post by OMNICELL »
I had this frustrating problem in Finale 2009.. I found a solution by unchecking the "Patch before play " check-box in the instrument box.... ! The point is that I believe the host sequencer is the problem , and not Mx4.. therefore, the MIDI Patch change command has to be removed from the track or sequence first....
Something like this..
Omni
A.K.A DA BARON
