WAVE AGENT LINK HERE
Features from their page include (some features are Windows only):
The bad... had a long session today at a post house in LA and my some of my DP files (all Bwave and time stamped) did not import into PT accurately. Time stamps were all wrong and a few were also reported incorrect by the above program, so it's not just a PT issue, but some aspects of it may be. Still have to suss that out.Playback of polyphonic / monophonic BWF and standard WAV files from any source, up to 12-tracks
Windows (7, Vista, XP) and Mac OS (10.4+) compatible
Supports up to twelve-track WAV files
View and edit metadata
Realtime monitoring of 788T meters and time code display with a connected 788T.
Correction of timecode stamps and frame rates
BWF split and combine via matrix
Batch editing, file-renaming and mono/poly file conversion
Create customized PDF sound reports
Multi-channel metering and monitor mixer
User-configurable graphic user interface (GUI) with drag and drop operation
788T Control Mode interfaces with the 788T via USB. Provides the ability to monitor 12 track meters in real-time, view time code in real-time, start and stop recording, and access the take list (With metadata editing).
The fuggly... Apparently a big part of the problem is that DP is apparently adding some kind of flag or code or indicator that shows up on import to PT as "Elastic Audio" and we think this may be the root of the problem.
