Display DP video full screen on dedicated DVI-TV?
by kestudi » Thu Jul 07, 2011 2:17 pm
My MacPro video card has two MiniDisplay ports and one dual-link DVI port. I'm converting the mini displays to dual-link DVIs for the computer monitors, and sending the native dual-link DVI to a 40-inch samsung LCD TV. MacOS sets up an extended desktop across three screens automatically.
What I'm wondering is: Can I use the TV as a dedicated display for DP video? I don't need to see the Mac Desktop on the TV; only DP video. Formerly, we were using a Canopus D/A box that sent DV video to an analog set. Hoping to achieve the same result with the new setup.
Thanks in advance for any tips!
- kestudi
Re: Display DP video full screen on dedicated DVI-TV?
by MIDI Life Crisis » Thu Jul 07, 2011 2:40 pm
I don't see why not. I believe the Mac will still use the 3rd screen real estate regardless when DP is not active. I do a similar thing with three screen but only 2 feeds (on my lowly G5). The 2nd screens are mirrored and because of the video splitter, and the different resolutions of the mirrored screens, I have to change resolution every so often to do various tasks. But if that works on my system, you should be fine. Once Sandy Bridge is released, I'll be diving into a new Mac Pro (or whatever they might be calling it) and doing exactly what you're planning, so I'm interested in your results.
Let us know how that works out, but I suspect you'll be just fine. I dropped the Canopus box as it introduced about a 1/3 second delay. The other nice thing is no more needing DV streams to see the video. simple (smaller!) Quciktime files are just fine.
_______________________________________________________________________
_____________________________MIDI Life Crisis_____________________________
_____________ML.3 • DP 64 bit • 8 core MP/20GB RAM • Track 16______________
MIDI Life Crisis - Posts: 17835
by kestudi » Thu Jul 07, 2011 2:54 pm
(we just upgraded from the lowly G5, btw
- kestudi
by MIDI Life Crisis » Thu Jul 07, 2011 2:57 pm
by kestudi » Thu Jul 07, 2011 4:39 pm
I'm just wondering if I can send video to a DVI monitor instead of to a firewire Canopus box.
- kestudi
by MIDI Life Crisis » Thu Jul 07, 2011 4:50 pm
by groove » Fri Jul 08, 2011 12:04 pm
If your work is critical and sync is a issue - i.e. dialogs editing, sfx, final mix - your are better with the resolution a dv stream offers when output to a TV screen.
Best
Mac Pro 2,66 GHz Quad-Core, 24GB ram OS X 10.8.3, DP8, LIVE 9, VE PRO5, custom Mac Minis, MOTU Traveller, UAD-2, UA 6176, UA 2192, Waves V9, LASS Full, VSL, Korg MS-20, Virus C, NI Komplete8, Alchemy, Stylus RMX, Minimoog V, Jupiter-8, Arturia Oberheim, GForce Oddity.
by MIDI Life Crisis » Fri Jul 08, 2011 2:40 pm
by groove » Fri Jul 08, 2011 7:49 pm
I'm sure you know this, but here is my workflow:
1. Set movie start time in the Movie mini-menu
2. Set Chunck start time accordingly
3. Copie movie audio to sequence
4. Mute audio track from movie window
5. Output movie to Firewire card (I disable the Echo video option)
6. Set video output playback offset to whatever your system needs (this will be constant to all your sessions and will not be influenced by the frame rate, Time code format or sample format of your sessions. The video output offset is related to the speed of the Firewire chips of your system and to the decoding card - in my case a ADVC-110. You can save your offset as a preset. Mine is 5 fr. 40 tc bits.
7. Work.
I never experience sync delay with that workflow, the ref audio track is played in sync from the chunk and my work is delivered without problems.
If you have problem with your Canopus, you might want to check the status of your card dip-switches. I remember I had to change something in mine, but it's been a while.
Cheers
by MIDI Life Crisis » Fri Jul 08, 2011 8:31 pm
Thanks for the info. If I attach a TV monitor to my system again, I'll give it a shot following your instructions. I'm pretty happy with the three monitor setup at the moment.
by martian » Sat Jul 09, 2011 3:24 am
my offset varies - if I am recording foley I use a TV as its quieter thats a 5 frame offset.
If I use the LCD projector for mixing it seems to need 8 frames - must be the LCD doing that..
www.fork-media.com
martian - Posts: 1809
by HCMarkus » Sat Jul 09, 2011 10:21 am
HCMarkus - Posts: 4040
by martian » Mon Jul 11, 2011 4:09 am
also I have great success with sony DV cams.. used an old (ten years old one ) for about 4 years - it died when the assistant some how dropped it..... then used a "HD"/ mini DV one for another couple of years too..
they can be quite good - and if your tight on space and no TV anyway using the camera fold out LCD has worked for me - just balanced in on top of my mon LOL..
www.fork-media.com
by pencilina » Tue Jul 26, 2011 9:57 pm
http://www.newertech.com/products/viddu2dvia.php
I had a firewire box but it had a lag this works great
pencilina - Posts: 497
by bralston » Mon Jul 23, 2012 10:37 pm
These Dual-link DVI adapters also require a USB port each for more power. But Apple give you an open UsB port on the adapter as a pass through. So you get them back.
This is why Monoprice's cheaper adapters don't work well because they do not have USB ports on the to reclaim those used ports.
But even this is not really full screen video. Until DP8's new video engine, FireWire non-HD is the only way to do that.
Brian Ralston
- 2012 MacPro 3.33GHz 6-core, 32GB RAM, OS 10.8.2, Graphics card: ATI 5870, UAD-2 Quad, DP 8.02
- 15" Macbook Pro 2.5GHZ Core 2 Duo, 4GB RAM, OS 10.8.2, DP 7.24
bralston - Posts: 459
Return to Digital Performer: Film/Video Scoring & Post Production
Who is online
Users browsing this forum: No registered users and 2 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
