It is currently Fri Jan 19, 2018 12:46 am
Text Size
Reconform experiment in DP
Digital Perfomer in the context of television/film scoring and post-production.
Postby bongo_john_uk » Sat Dec 09, 2017 4:49 pm
I make an app that is a collection of some useful audio post production tools.
Today as an experiment I decided to see if I could also get an automated reconform applied to DP from a picture edit change list. I wrote a hammerspoon script that interprets a change list produced by my timeline compare tool & sends appropriate keystrokes to DP. It seemed to work pretty well.
The script is basically interpeting a change list produced by comparing two xmls for FCP X in my app.
Mac Pro 12 core 3 GHz, Motu Ultralite, DP9.1, Mac OS X 10.10.5 64GB Ram.
http://limbicsounds.com
bongo_john_uk
Re: Reconform experiment in DP
Postby FMiguelez » Sat Dec 09, 2017 5:20 pm
:shock:
If this is what I think it is, you will have scored a homerun, John.
Please tell us more about your app!
Mac Mini Server i7 2.66 GHs/16 GB RAM / OSX 10.10.3 / DP 9.02
Vienna Instruments SUPER PACKAGE, Waves Platinum, slaved iMac and Mac Minis running VE Pro, etc.
"There's random genetic variation, and non-random survival, and non-random reproduction, which is why, as the generations go by, animals get better at doing what they do. That is quintessentially non-random". ― Richard Dawkins
FMiguelez
Postby bongo_john_uk » Sat Dec 09, 2017 5:27 pm
FMiguelez wrote::shock:
Please tell us more!
The last release of my app added a compare tool that allows you to compare two picture drafts in XML (Premiere), FCPX XML (FCPX/Resolve) or EDL (Media Composer).
That produces a change list file (VCL/EDL) which can then be fed into a script that automates the process for various DAWs. Today I added DP to the script.
http://vordio.net/the-new-compare-function/
bongo_john_uk
Postby MIDI Life Crisis » Sat Dec 09, 2017 6:26 pm
2013 Mac Pro 32GB RAM
OSX 10.12.6; DP 9.5; Track 16 Finale 2014.5
http://www.MIDILifeCrisis.com
Postby cuttime » Sat Dec 09, 2017 6:36 pm
Traveler DP9.51 Unisyn 10.6.8 and 10.13.1 i7 iMac 16G
Postby bongo_john_uk » Sat Dec 09, 2017 6:48 pm
It basically makes it easier to deal with picture edit changes. So you can resync your audio edit to match what the picture editor changed. It shuffles the edit around to fit. Only relevant to working with video editors.
bongo_john_uk
Postby MIDI Life Crisis » Sat Dec 09, 2017 9:03 pm
I'd have to see it in action in a practical setting, but I sort of understand where he is going with this. Or do I?
Postby bongo_john_uk » Sun Dec 10, 2017 5:50 am
I'll hopefully get time next week to make a walkthrough video. Seeing the whole process might makes things clearer.
For now a simple example is this short film. A scene in the middle was removed between draft 8 and draft 9. So part of the audio sequence will now have to be removed and the 2nd half moved back to fit into the gap created.
bongo_john_uk
Postby MIDI Life Crisis » Sun Dec 10, 2017 12:03 pm
How does this deal with cues that extend into the deleted region? Conversely, how does it deal with inserted scenes that may overlap into existing ones? Seems like a valuable tool.
Postby bongo_john_uk » Sun Dec 10, 2017 1:17 pm
Yes a region-based approach to reconform can't deal with overlaps well.
It will destroy some of the work at edges of changed regions. So those edges need to be checked. That's exactly why my script drops markers at those points. So you know where to check for potential issues. It still saves a lot of time over manually moving things by typing in timecodes though.
There is also a more fine grained item-based approach that is much less destructive and can deal with overlaps between scenes etc, but that is not possible with DP and most other DAWs either. To make it possible the DAW needs to have certain features to track items individually across drafts. It needs a documented open project format that can be manipulated plus the ability to embed tracking metadata in each item. In another DAW I do embed tracking IDs for each item in item notes, but DP doesn't have per-item notes, nor an open format, so I couldn't do that approach with DP.
bongo_john_uk
Return to Digital Performer: Film/Video Scoring & Post Production
Who is online
Who is online
Login Form
