Chorder, Tonal Harmonizer, and Strum scripts work as well as expected within Mach Five 3.
But what I would like to do is to have Strum (or use another script) to change the order which notes of a chord are sounded to produce a more humanizing rolled or broken chord:
1. Up - Notes are sounded in order from lowest note to highest note
2. Down - Notes are sounded in order from highest note to lowest note
3. Alternate - the order in which notes are sounded changes each time you play a keyboard
4. L Down - the lowest note is sounded first and then the notes will be sounded in order from the
top down. *if you trigger chord C-E-G-B the not will be sounded as C-B-G-E.
5. U Up - the highest note is sounded first and then the notes will be sounded in order from the bottom up. *If trigger chord C-E-G-B the notes will be sounded as B-C-E-G.
^^^^This is a feature found in the Fantom G that I would like to accomplish wishing Mach Five is possible.
Does anyone have a script like this that can share or sell?
Script Experts: Chords, Strum, and triggering order of notes
