Map for both velocity and round robin(osc) on bulk import ?
I'm trying to use a huge(perhaps excessive) drum sample kit. There are 127 velocities and 4 samples for each, so 508 samples. Is there a way to name the files so I can create the proper velocity stack for keygroups as well as adding each of the 4 round robin oscillators for each? I know you can option/alt drag and that gives options but I don't think they meet both of these criteria. I need to check the Machfive Lua docs again but perhaps you can script imports as well. Thanks!
Re: Map for both velocity and round robin(osc) on bulk impor
Sorry, I think I inserted my own question, which I guess isn't bad. I had to add the note name to each file so as to use the note->velocity->round_robin auto mapping. I used OS X automator to simply replace the filenames and, boom, Machfive imported everything perfectly. Pretty cool.
