Changing presets but keeping fx used
Hi folks,
I'm just wondering if it's possible to do the following.
I load up a preset, lets say an EP and I add an arp and some reverb etc. I like what the arp and reverb are doing and i want to change the preset instrument, but keep my FX. Is this possible?
http://soundcloud.com/rockshamrover" onclick="window.open(this.href);return false;
Born to run, but mostly walk.
Re: Changing presets but keeping fx used
Save the presets as a preset group (forgot what that's called).. You can call up that specifying grouping of presets. I think it's a drop down on the top right of the mixer menu and probably a control-click on the preset name in the list.
Thanks MLC, I think I figured it out
I tried the "load as layers" thing at the bottom of the main screen, so it lets me have multiple versions of presets for the same instrument, I can then have the same fx on each. Mute the ones I don't like etc.
It's a bit long winded, but it's working
I'm on my machine now. At the top of your inserts there's a gray box. Select SAVE INSERT SETTINGS.
Then when you want to call up that setup, hit the gray box again and the saved insert (which you can and should give a name to or it defaults to a lucg name) will appear in the center drop down menu.
THAT is how you do it.
That's excellent
Thank you very much.
Don't that me. Thank MOTU. Ok, you can thank me.
You're welcome.
You're welcome.
That'll do!
