Instances in previous sessions not retaining pre-sets
My previous PT sessions with MachFive instances now default to 4 blank MIDI channels, and lose all presets I had previously assigned. Running MachFive 3.2 in Pro Tools HD 10.3.5. Have a MOTU tech working on this, but was wondering if anyone else had any suggestions regarding this serious problem. Thanks for checking.
Re: Instances in previous sessions not retaining pre-sets
RTAS/AAXjs_nyc wrote:My previous PT sessions with MachFive instances now default to 4 blank MIDI channels, and lose all presets I had previously assigned. Running MachFive 3.2 in Pro Tools HD 10.3.5. Have a MOTU tech working on this, but was wondering if anyone else had any suggestions regarding this serious problem. Thanks for checking.
try removing the AAX version.
Looks like PT mess some stuff when plugins move from RTAS to AAX from time to time.
I wish it was that simple. I went down to V3.0.1 on PT 10.3.8 and found the presets intact. I then went through all sessions and saved each MachFive Performance. Since there were other bugs with my other virtual synths when I was in this state, I went up to V3.2 again. All the MachFive instances went back to default settings, and when I tried to launch a saved preference, it also loaded up in the blank default state. I am now waiting on MOTU tech for reply...
Have you actually tried ?js_nyc wrote:I wish it was that simple. I went down to V3.0.1 on PT 10.3.8 and found the presets intact. I then went through all sessions and saved each MachFive Performance. Since there were other bugs with my other virtual synths when I was in this state, I went up to V3.2 again. All the MachFive instances went back to default settings, and when I tried to launch a saved preference, it also loaded up in the blank default state. I am now waiting on MOTU tech for reply...
3.2 is the only version with AAX available.
Thanks for the reply. I am now on v3.1.4 of MF, with PT 10.3.8. I get all of my "multis", but now every VI has a weird pulse the makes a sound loop, rendering it unusable. I was even able to record this artifact to a MIDI track last night- it is the first MIDI note and just randomly loops. Even when "standing still" (not even record-enabled), this "trigger/pulse" causes the VI preset to sound this loop. So I do not have the aax version in play, and now have this other problem. I am all over the PT Users board now as well.
