DP no longer finds Mach5 3
bkshepard
Re: DP no longer finds Mach5 3
Post by bkshepard »
You might try physically removing the MachFive component from the Library>Audio>Plug-ins>Components folder and then reinstalling. I'm pretty sure M5 comes in both 32-bit and 64-bit versions.
-Brian
Mac M1 Ultra 20-core, OS 14.3.1, 128 GB RAM, DP 11.3.1, UA Apollo x6
NealF
Post by NealF »
OK. I broke down and called Motu tech support.
Basically (as best as I can remember) he had me get rid of the prefs and the whole DP folder that had all the plugins. Then I restarted the program. This forced DP to check all the plugins again. Took a while, but Mach5 3 now worked.
It wasn't a problem with 32 or 64 bits. I guess the program is smart enough to know which you need. Dunno.
But it's working now.
Thanks to all of you for your advice and help.
MacPro5,1 6-Core Intel Xeon, Processor Speed: 3.46 GHz
Number of Processors: 1
Total Number of Cores: 6
L2 Cache (per Core): 256 KB
L3 Cache: 12 MB
Memory: 32 GB. Mojave. DP 9 and Apogee Duet.
bkshepard
Post by bkshepard »
Cool, glad you got it fixed!!!
-Brian
