Sound flower? What the... Finale?
Posted: Wed Aug 31, 2016 9:33 am
by MIDI Life Crisis
I installed Finale 25 last week and promptly uninstalled it. That is the only change to my system. Now out of nowhere, Soundflower has appeared and even bypassed my usual MOTU driver for Track 16. I tried to download the Soundflower app to run the uninstall and even ran a script provided with the DMG from the developer, but the script failed to remove the extension.
I'll start digging thru my library for Sunflower extensions, unless someone has a better solution, but what a PITA!
Re: Sound flower? What the... Finale?
Posted: Wed Aug 31, 2016 9:45 am
by mikehalloran
If you have an old install, you have to disable SIP to remove everything—then reenable it, of course. The latest Soundflower build does not install where it shouldn't.
I posted the basics on how to do this awhile back. I'll see if I can find that link.
Posted: Wed Aug 31, 2016 9:52 am
by MIDI Life Crisis
Thanks. Mike. What is an SIP?
Posted: Wed Aug 31, 2016 10:01 am
by Tonio
security integrity protection
https://support.apple.com/en-us/HT204899
Just go to security in system pref's and turn it off, to install/uninstall non Apple apps.
Posted: Wed Aug 31, 2016 10:22 am
by MIDI Life Crisis
Thanks. The Library has lots of folders and oddly named entries that may also need to be removed. I wish it were as easy as that link makes it sound...
Posted: Wed Aug 31, 2016 11:03 am
by MIDI Life Crisis
mikehalloran wrote:If you have an old install, you have to disable SIP to remove everything—then reenable it, of course. The latest Soundflower build does not install where it shouldn't.
A guy in the MM forum provided the answer: KILL THIS
I also found a few .kext files for hardware related stuff I don't use. Gone!
Posted: Wed Aug 31, 2016 11:04 am
by MIDI Life Crisis
Thanks for your help!
Posted: Sat Feb 04, 2017 8:06 pm
by mhschmieder
I was hoping this was the answer to my own Finale launch problems, but the Sound Flower extension doesn't show up on my system, and if I audit that entire directory, no suspicious extensions show up.
I'll re-run the font manager now just in case I hadn't done that lately.
EDIT: Font Book found no duplicate fonts. I guess my Finale problem is unique to my system.
