How does one repair permissions?
Jeroleen
Post by Jeroleen »
I have been getting a bunch of freezes and crashes lately. I am using a Dual 2.0 G5 with 10.3.6 and DP 4.5. Everything is the latest and "greatest".
I seem to get a lot of problems when using Kontakt as a plug-in. I am generally able to control the problems by simply slowing down when I change from one mode to another. For instance, if I load Kontakt and immediately attempt to load an instrument DP will sometimes freeze.
The problem however is that I am getting alot of freezes and crashes even without the use of Kontakt.
I figure I should start with repairing permissions 'cept I don't know how that is done
sdfalk
Re: How does one repair permissions?
Post by sdfalk »
Go into your utilities folder, open Disk utility, select your boot drive and you should see the option to repair permissions.
Click it and you're on your way.
A Metric Halo ULN8-3D…mmmmmmm
Jeroleen
Post by Jeroleen »
Thanks sdfalk. I figured it was simple but it is always best to check a bit first. By the way, is this something that can correct an abubdance of crashes. I realize it is all circumstantial but given the right criteria, is this fix at least in the ball park?
tmcclintock
Post by tmcclintock »
You might also want to look at optimizing your system. The Unix Kernal OS X is built in needs periodic maintenence. There are a number of good utilities out there, but here is one I like.
http://www.mkd.cc/
Download the System Optimizer X software.
t
Tiger/17" G4 PowerBook/1.5 Ghz Single/1GBRAM/Apogee MiniMe and MiniDAC Converters/HR8-24 Monitors/DP 4.6/Waves Platinum Bundle/Peak/T-Racks/FinalCut
"The Higher the Predictability, the Lower the Connectivity"
“If you don’t like change, you’re going to like irrelevance even less.â€
studiodog
Post by studiodog »
And don't shut your mac down every night.
OS X will run utilities and do maintenance every night, especially on Sunday nights.
Helen
Post by Helen »
Try Macaroni. http://www.atomicbird.com/
It automates the process, and allows you to run stuff manually when you see fit. It also allows you to shut down at night if you want.
Mac Pro Rack 7,1 3.2 Ghz 16-core, OS 11.6.1, 192GB ram
MOTU 828es, DP 11.02, Altiverb, Kontakt 6, VEPro
This job is fun, this job is fun....
midiw
Post by midiw »
I use Macaroni to do the routine UNIX stuff all in the background without leaving my machine on all nite.
I also discovered that using TechToolPro 4 helps to optimize/defrag the hard drive and to restore the OS directory. I run TTP4 weekly or even immediatly after I have installed a new program or AU/VST plug.
Moeny well spent on having both.
Mac OS: Mojave
twistedtom
Post by twistedtom »
Mac Janitor is free, works well. I have had good luck with Drive 10 and Tech tools Pro. I have had bad luck with Nortons.
lordtom
Post by lordtom »
I use "cocktail" for the past year with no a single problem with my generation A DP 1.8
Mac DP 1.8 6 gig ram
