Yosemite Tips and Tricks...
Re: Yosemite Tips and Tricks...
I'll list a few highlights I like (if anybody cares.... or wants to fight over them!)
#1 BATCH RENAME in the Finder
#2 FaceTime calls from the Mac (I wish I could make all my calls from there)
#3 Expand (green dot) moves any app to full screen.
- Guitar Gaz
...and if you do this in DP you can't get it back from full screen. I believe this is what they call a bug......MIDI Life Crisis wrote: #3 Expand (green dot) moves any app to full screen.
Gary Shepherd
____________
iMac 27" 3.3 GHz Intel Core i5, 32 GB Ram, Monterey 12.7.4, 64 bit, Digital Performer 11.2, Studio One 6.5 Professional, Reason 11, Melodyne 5 Editor, Korg Legacy Wavestation and M1, Arturia minimoog V, Helix Native 3.72, Bias FX 2 Elite, Superior Drummer 3, EZkeys, EZbass, Nektar Panorama T4, Motu M4, Faderport 2018, Gibson Les Paul Standard, James Tyler Variax JTV-59 and other gear.
____________
You can go to the upper right corner and take it out of full screen.Guitar Gaz wrote:...and if you do this in DP you can't get it back from full screen. I believe this is what they call a bug......MIDI Life Crisis wrote: #3 Expand (green dot) moves any app to full screen.
Right. Don't you just hover your mouse up in the upper right and the menu bar reappears and you click the little icon to come out of full screen mode?MIDI Life Crisis wrote:You can go to the upper right corner and take it out of full screen.
Mac Studio M1 Max, 64GB/2TB, MacOS 14.4.1 Sonoma, DP 11.31, MOTU 828es, MOTU 24Ai, MOTU MIDI Express XT, UAD-2 TB3 Satellite OCTO, Console 1 Mk2, Avid S3, NI Komplete Kontrol S88 Mk2, Red Type B, Millennia HV-3C, Warm Audio WA-2A, AudioScape 76F, Dean guitars, Marshall amps, etc., etc.!
- Guitar Gaz
No that doesn't work anymore - in Yosemite it should now be the left hand corner and this does not work in DP. In other apps the green button appears in the left hand corner when you hove the pointer there. Of course in DP that does not work. So it needs fixing - tried to report it to Motu but got a security warning about their site. Has anyone else reported this obvious bug?
Gary Shepherd
____________
____________
re: My earlier post: I was WRONG WRONG WRONG! I got the error just now as well. No collapse arrows in the menu bar! I swear they were there yesterday!
Apologies guitargaz! You are correct - it is a bug!!!
Bummer. I haven't tried it. I don't use the consolidated window much and found I never used full screen mode much for DP.Guitar Gaz wrote:No that doesn't work anymore - in Yosemite it should now be the left hand corner and this does not work in DP. In other apps the green button appears in the left hand corner when you hove the pointer there. Of course in DP that does not work. So it needs fixing - tried to report it to Motu but got a security warning about their site. Has anyone else reported this obvious bug?
- Guitar Gaz
No worries - there has been some strange window behaviour but so far settled down. And as I posted on another topic: "And the problem with the full screen mode prompted me to do something I should have done ages ago - get rid of the Dock! Okay its been shrunk down and hidden by me - and I have now got Top Hat running as an app launcher. So I have less need of the full screen mode."MIDI Life Crisis wrote:re: My earlier post: I was WRONG WRONG WRONG! I got the error just now as well. No collapse arrows in the menu bar! I swear they were there yesterday!
By the way still getting a security warning when I try to use MOTU Tech Links to register this bug. Is anyone else getting this problem - and can they register this bug Motu because I can't seem to at the moment?
Gary Shepherd
____________
____________
- Steve Steele
I had a nice little Finder Service that I made for batch renaming files. I guess Apple made a little Automator script.
Still it's good to have stuff that's there out of the box.
I know that Yosemite is basically Maverick's code with a face life, still I'm nervous about installing it. I'm not sure my 2008 MacPro will pickup phone calls, and AirDrop better work between my iOS devices and my MP. I need to check, because if not, I'm sticking with Mavericks (unless Apple cleaned up some audio subsystem that I didn't know about).
At least Ivy didn't go too "Hello Kitty" with OSX.
There was a work around to make AirDrop work on MP 3,1 which I tried. It didn't work for me. I had read it's a hardware issue not OS, but I could be wrong. Haven't tried again in Mavericks. I'm still using file sharing. I'd love for AirDrop to work on the 3,1. It's a useful feature.
Frank Ferrucci
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
- Guitar Gaz
Have managed to contact Motu Tech links about Full Screen mode and they have responded that it is a bug and being looked at.Guitar Gaz wrote: By the way still getting a security warning when I try to use MOTU Tech Links to register this bug. Is anyone else getting this problem - and can they register this bug Motu because I can't seem to at the moment?
Gary Shepherd
____________
____________
Yosemite Window server problems: FWIW
http://www.macissues.com/2014/10/20/pre ... mite-down/
828x MacOS 13.6.5 M1 Studio Max 1TB 64G DP11.31
Thanks for posting this. It's strange that this would happen; there were window server issues in earlier OS versions too. They "went away", so no doubt Apple knows why it's happening.
I know a lot of you use Audio Hijack Pro. FYI:
http://www.macworld.com/article/2837811 ... aster.html
