Dell UltraSharp U2713HM 27" Monitor
Anyone using one of these w DP and can recommend? Amazon has them for $568. Thanks.
Frank Ferrucci
http://www.ferruccimusic.com
Re: Dell UltraSharp U2713HM 27" Monitor
Here's a review.
http://www.cnet.com/products/dell-u2713hm/
Nowadays when comparing monitors, I always pay attention to power consumption since it = heat.
Monitors have become much more efficient over the last few years.
- BKK-OZ
I have one of these: http://www.dell.com/ae/business/p/dell-u2711/pd and I do like it.
You will want to invest in a decent arm/stand (I have a fully articulated, heavy-duty one).
It does give off heat too, and no doubt it isn't the most fuel-efficient out there, but as a display, it is pretty hard to beat.
Cheers,
BK
- M Kaku
BK
- M Kaku
PowerBKK-OZ wrote:I have one of these: http://www.dell.com/ae/business/p/dell-u2711/pd and I do like it.
Voltage Required:
100 to 240 VAC / 50 or 60 Hz ± 3 Hz / 1.5 A (typical)
Power Consumption (Operational):
60W(typical) / 130W(maximum)4
Power Consumption (Stand by / Sleep):
Less than 0.5W
Power Consumption (Operational)Dell UltraSharp U2713HM 27" Monitor
42W(typical) /100W(maximum) 4
Power Consumption Stand by / Sleep:
Less than 0.5 W
By comparison:Apple Thunderbolt Display
http://www.apple.com/displays/specs.html
Input voltage: 100-240V AC; 50-60Hz
Maximum power: 250W (Thunderbolt Display while charging MacBook Pro)
Energy saver mode: 2W or less
Subtract 85W to get the estimated monitor draw of 165W peak. Per the CNET review, typical power draw is 106.5W–higher than comparable Dells but much, much lower than other monitors just a few years ago.
http://www.cnet.com/products/apple-thun ... display/2/
I bought a couple of these large Dell 30" monitors to replace two 24" Dell monitors I had been using for a few years.
http://www.dell.com/en-us/shop/accessor ... s/225-4429
They are great and they run A LOT cooler than the 24" monitors. My "studio" space is small, so the heat savings was important.
Because of their size, the articulated arms I had been using were not very effective. Turns out the stands they came with worked great for my set up.
Cheers
Cheers
10 core iMacPro | 64 GB RAM | OS 12.6.7 | LOGIC PRO | STUDIO ONE 6 | CUBASE 12 | BITWIG 5 | DP 11 | MOTU Interfaces | Waaay Too Many Plug-ins |
http://www.gesslr.com
Thanks for the discussion. I noticed before I posted that the power consumption on the u2713 was low. I'd go with the Apple Thunderbolt Display but I'm using a Mac 3,1 as music computer. No thunderbolt.
Frank Ferrucci
Frank Ferrucci
Frank Ferrucci
I went with two of these (below), side by side on an arm. More (and bigger) pixels for fewer dollars better suited my eyes (and wallet.) I have owned for two years and have been been quite pleased. Connected to ATI 5770 with miniDP to DP cables from Monoproce.com.frankf wrote:Anyone using one of these w DP and can recommend? Amazon has them for $568. Thanks.
http://accessories.us.dell.com/sna/prod ... u=320-2676
