10.9.4 now out
- joelfriedman
10.9.4 now out
Anyone dipping into the water?
http://www.macrumors.com/2014/06/30/app ... es-10-9-4/
Joel Friedman
iMacPro 2017 3.2 GHz, OS 13.6,3 32GB RAM, 4 1 TB HD's (boot, project, and samples), MOTU UltraLite MK4, Nektar Impact LX88
DP 11.3, MachFive 3.2, MX4 2.2, Ethno 2.01, Komplete 14 Ultimate (don't ask...), Sibelius Ultimate, Symphobia v. 1.06, assorted libraries...
MacBook Pro M1 16 GB RAM OS 13.6.3
Re: 10.9.4 now out
Updated an hour ago but haven't run DP yet.
- mhschmieder
Re: 10.9.4 now out
Did the Combo Updater this time as it's been awhile and I was starting to suspect some missing dependencies here and there.
Am about to run DP now, on a fairly complex project.
Everything else seems... snappier.
- mhschmieder
Re: 10.9.4 now out
DO NOT INSTALL THIS UPDATE!!!!!!!!!
Even with a fresh from-scratch default no-content project, DP 8.06 is crashing REPEATEDLY.
Re: 10.9.4 now out
I'm running 7.24 on 10.9.4 and have no problems.
Signed, Single Datum
Re: 10.9.4 now out
I feel your pain. I sure hope you made that clone.mhschmieder wrote:DO NOT INSTALL THIS UPDATE!!!!!!!!!
- mhschmieder
Re: 10.9.4 now out
Premature Burial.
One reboot is not enough. Rinse. Repeat.
I also did Repair Permissions after EACH reboot.
Then, the next time I opened DP, I used a blank template to make an empty new project on my main SSD system drive, far away from my "real" projects.
After that, I had a valid Audio Units Info Cache again, and could restart with a real project that has lots of MIDI and audio.
If I get another crash, I'll report back.
UPDATE: I did some pretty heavy lifting for several hours late last night, and no crashes in DP after my third round of reboots and Repair Permissions.
Re: 10.9.4 now out
A lot more permissions had to be repaired than normal but I had no issues in DP 7.24 or 8.
What you are describing is similar to what I went through with the OS 10.9.1 update. In Console, I discovered that the Mackie HUImdriers were failing to load - weird because i make no calls to them. I wound up reinstalling DP 8.05 and rebooting. Fixed me right up.
- joelfriedman
Re: 10.9.4 now out
Wow, gave me pause as I stupidly updated while in the midst of a small project. I hadn't opened DP yet but immediately booted up in Recovery mode and repaired disk and permissions a few time just to be safe. Everything is fine here in 10.9.4/8.06, etc.
Not my smartest move...
Joel Friedman
Re: 10.9.4 now out
FYI: iOS 7.1.2 is out as well.
Re: 10.9.4 now out
Hyperbole aside, after repairing permissions (and there were quite a few) I ran DP all day yesterday and started a couple of hours ago today and not one problem except I can't scrub MIDI notes on my Plugsound Pro VI. I haven't tried shutting off pre-render yet (likely cause) but otherwise, everything is running just peachy keen.
Re: 10.9.4 now out
I did a check disk and repair permissions before and after updating. The disk was fine before updating, but I had to do a disk repair from the recovery partition after the update. Maybe just a coincidence?joelfriedman wrote:immediately booted up in Recovery mode and repaired disk and permissions a few time just to be safe.
Re: 10.9.4 now out
I've noticed no change in anything with 10.9.4 on any of the Macs I've updated - 6 so far. I always run from the Combo Updater and repair permissions upon reboot.
I did have wake from sleep and Magic Trackpad issues after 10.9.3 but it was the Chrome browser that was the culprit when I had too many GoogleDocs open. Weird. Anyway, Google fixed that a few weeks ago.
My day job has me starting up with 60+ tabs open on two screens including 10 with GoogleDocs. Chrome is the only browser that handles that well - when it behaves. One thing I like is that, when Chrome acts up, I can place a trouble ticket through the Tools menu. It's not unusual for such problems to be fixed within hours.
- menright
Re: 10.9.4 now out
DP 8.06, OS 10.9.4, Mach5 3.2 and no problems except for a free version of the Eventide UltraChannel plug-in that crashed DP and also the latest version of Final Cut Pro.
MacBook Pro 17' 2.66 GHz Intel Core i7, 8 GB, DP9.1, MachFive3, Ethno2, Synthmaster, Waves, UVI, Ableton Live
Re: 10.9.4 now out
No problems here, either.
