G5 toslink out to ADAT?
filmscoraldo
Post by filmscoraldo »
Is the physical Toslink plug that works with a G5 the same cable used for ADAT i/0? I know the G5's output is only 2 channel, but can I use it as an output to a 2408? Do the digital protocols work together?
Thanks,
SG
It's not that I'm so smart, it's just that I stay with problems longer.
-Albert Einstein
barks
Re: G5 toslink out to ADAT?
Post by barks »
Adat and SPDIF both use the toslink system as far as I know. On my 828 it can be either spdif 2 channel or adat depending on the configuration of the firewire settings.
So you should be able to use the same optical cable.
Barks
iMac 2GHz Intel Core 2 Duo 2gig ram, DP5.12 (err, back to 5.11 actually...), RME Fireface 800, ADA8000, RME ADI-2 Converter, Allen & Heath GS3 24 channel mixer, Genelec 1030, dbx Drawmer Focusrite Roland Lexicon TC outboard, studio sofa + kitty...
