Is my Early 2008 Mac Pro 64bit capable?
- Renaissance Man
I'm itching to upgrade all of my software but was under the impression that my Early 2008 Mac Pro is not capable of 64 bit operation. The newest DP, Waves and most other of my softwares are now 64 bit.
Can anyone tell me how to tell conclusively if my machine is 64bit capable?
New in February 2008
Dual 2.8GHz Quad-Core Intel Xeon "Harpertown" Processors (8-cores total) w/12MB of L2 cache per processor (6MB shared per pair of cores),1600MHz dual independent frontside buses
16GB 800MHz DDR2 fully buffered ECC memory in eight FB-DIMM slots
1- 320GB 7200-rpm Western Digital SATA 3Gb/s hard drive
Mac Pro Mid 2012 12-core 3.46GHz, 128GB RAM, SSD, Mojave, DP11; Waves Mercury & SSL 4000 Collection, SyncroArts VocAlign Project 3, EastWest Quantum Leap Pianos & Voices of Soul, Nomad Factory Integral Studio Pack, BBE D82 Sonic Maximizer, Slate Digital VCC, RC Tube and Trigger, MOTU PCIe 424, 3-2408Mk3's, 24io, MTP AV USB, Apogee A/D & Big Ben, CraneSong HEDD 192, ATC monitors, tons of outboard & microphones, MIDI/keyboard rig, house drums & tuned percussion...
Re: Is my Early 2008 Mac Pro 64bit capable?
Check about this Mac details. If it's a 3.1 or better machine you're good to go.
Yes... and we go round and round with this one every time. Even the MacPro 1,1 can run 64-bit apps and break the 4GB limitation of RAM for an app. Even though it cannot boot into the 64-bit kernel, a MacPro 1,1 running Snow Leopard can run DP in 64-bit mode and access more than 4GB RAM.
But it can't run Lion or better.
True enough. I didn't see the original post ask about that, just if it were 64-bit capable.MIDI Life Crisis wrote:But it can't run Lion or better.
I actually read it and thought about the OS, but of course you are correct about the info you provided. It remains confusing for many.
- Renaissance Man
I believe this is what you're asking for: (Just want to make sure before I plunk down a pile of cash upgrading all my software)
Hardware Overview:
Model Name: Mac Pro
Model Identifier: MacPro3,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 16 GB
Bus Speed: 1.6 GHz
Boot ROM Version: MP31.006C.B05
SMC Version (system): 1.25f4
Serial Number (system): YM7523RAXYK
Hardware UUID: 7BCACB87-B01D-5B95-ADD1-2D21B794B203
Hardware Overview:
Model Name: Mac Pro
Memory: 16 GB
Bus Speed: 1.6 GHz
No biggie. Just wanted someone else who might own an MacPro 1,1 and might read this topic not to junk their 1,1. I still have one of those machines and they're still quite capable for many things. Although doesn't make sense to buy RAM for those things now... better off getting a newer one. I made out like a bandit getting my 4,1 for $699. Put 24GB in it and I'm good.
- Renaissance Man
So are you saying my Mac Pro 3.1 isn't able to run Lion or 1.1?
Last edited by Renaissance Man on Sat Apr 19, 2014 2:47 pm, edited 1 time in total.
Good move, JS. I'm eyeing the SSD market as we speak. That should keep this old gal humming...
Look here:Renaissance Man wrote:So are you saying my Mac Pro 3.1 isn't able to run Lyon or 1.1?
http://support.apple.com/kb/HT4949?view ... cale=en_US
Also, you don't want to run Lion. Mountain Lion of Mavericks. Some folks are reporting Maverick issues. It works great on my 3,1 machine.
- Renaissance Man
Thanks. Just checked and my early 2008 Mac Pro is Mavericks capable, so there's one software down...
- Renaissance Man
Will Mavericks run in 32 bit mode? I'd like to upgrade the Mac OS first and don't want to cripple my system...
- Renaissance Man
For any future readers of this thread... Just found this link through MOUT's Tech Support page located at: http://www.motu.com/techsupport/technot ... patibility
The Apple link is: http://support.apple.com/kb/HT3696
32 bit apps will run in a 64 bit OS. The OS, however, can only run in 32 bit. A 64 bit DAW cannot run 32 bit plugs unless you use a shell such as bridge or Plogue Bidule (there are a few others). It's kind of a PITA so check the plug mfg for 64 bit compatibility if you go that route. Also, be sure some of your other programs will run. Quicken needs a patch from their website. Some Adobe might need updating as well and that can be expensive, especially since you now have to rent the software on a yearly basis from some apps to move to the current versions.
