new dual G5, suggestions, please
I'm planning to purchase a new G5 dual 1.8. I plan to run DP4, also considering Mach5. I'll need to upgrade my current 2408mkII PCI.
I'l probably add another internal drive.
How much RAM should I plan to add?
Any other issues I should be aware of?
G
G
if it sounds good, it is good - ellington
macbook pro 2.53 4G OS 6.8 DP7.22 828mkII
Re: new dual G5, suggestions, please
at least a gig two would be smokin
Get a MAC:G5 1.6 G4 1.25 G3 500 imac 400
ibook 500 DP4.52 ProTools TDM and tons
of soft synths and hardware
I wouldn't go less than 2gb ram.
:p
:p
Dual G4, 1.42GHZ, 2,048 ram, 3-74gb Raptors, 1-250gb Caviar, OS X Tiger 10.4.5, D.P. 4.61, HUI, Tannoy 600a's, UAD-1,Fairchild, Pultec-Pro, tc PowerCore firewire, Restoration Suite, MD3, VSS3, Inflator, Voice Modeler, Assimilator, Auto-Tune4, PowerCouple, PSP MasterQ, Vintage Warmer, MixPack, Blue Tubes Bundle, BFD, motu 896 HD.
http://www.inukshukproductions.ca/mastering
Thanks to both - I've budgeted for the extra ram - 2G.
I've been planning also for a 2nd drive to store music files only. Internal or external/firewire? Advantages/disadvantages? Portability, noise level, access time... time to do some reading.
G
G
I usa a second internal SATA drive for audio on my 2x1.8, and external fw drives for backup and for taking projects/files to other studios. No probs with the internal SATA (Hitachi)so far.
- Timeline
Sonnet Tech makes a SATA to ATA converter for about 60 bucks if you want to continue with an older drive on your new machines.
I bought one and it works great!
Cheers
Cheers
I've decided to go w/ SATA internal, and FW external for portability, b/u...
The ultra-wide SCSI drive (pci) won't run with the new system - ppl OWC (aka macsales.com) said it would be costly to use it (conversion/adaptor) with the new box. Hence, FW drive.
Time to get all my software upgrades in order.
