BFD on DP
Re: BFD on DP
Works great for me, both via AU and ReWire.
- rikp
Re: BFD on DP
Also works great for me in DP 4.5. Don't upgrade to 4.5.1 that is where problems will start!
Rik
Rik
http://www.coffeecupmusic.com
Mac Pro 8 Core 22 Gig RAM, 2 Hackintoshes, DP 8, ProTools 11, Logic X, Waves, Kontakt, Vienna Strings, EWQL Platinum, GPO, BFD, Omnishphere, Stylus RMX, Trilogy, Altiverb, DrumCore, EZ Drummer, LASS, HollyWoodwinds, and too much money spent on VI libraries.
Re: BFD on DP
I did try the VST instead of AU and it sounds so much better.
Try it if you can.
I used Vstau from FXpansion,
SB
Try it if you can.
SB
iMac 27" i7 4.0, 3Te.32 G of Ram, Apollo Silver with TB expansion (coming up).
Re: BFD on DP
What kind of sonic improvement did you get using the wrapper instead of native AU? I'm currently using AU and am pretty happy with the sound, and not sure I want to buy the wrapper just for one plugin, but I will if it really sounds better.Originally posted by slybass3000:
Try it if you can.
SB
RA
Re: BFD on DP
At first,I did notice in a certain project a big sonic difference between the two.
I made sure that everything was exactly the same on both plug-ins and the VST sounded much better and louder.
Then I started a new project with that in mind and after testing I didn't notice any differences at all between them!!??
So, I don't know what was the deal.
I do notice a much faster loading time with AU,
I'm still suspicious about the VSt compare to AU.
I'm back with AU right now.
Good luck
SB
Good luck
SB
