Listen up folks !!!! I think I have a solution for the stuck MIDI notes when using external synths everyone is experiencing
It's obviously a USB 3 vs the older USB .... a simple hub might work
I had stuck notes consistently until I stuck the USB coming from my Microlite to one of the USB ports on my Apple Keyboard ...
I am using an older wired (short) Apple A1242 Aluminum Keyboard with 2 USB ports
I've played 2 MIDI songs using only external synths in 2 different DAW and NO STUCK NOTES !!!!!!!!!.... I could stop and start with NO STUCK NOTES !!!!!!!!
I hope this is a true fix until MOTU hardware catches up to the USB3 ~!!!!!!!!
Hope it works for everyone else because I don't know about you guys, but for me the thought of letting go of my 30yr old ESQm for a VST is not a pleasant one ......
Stuck MIDI notes Mac OS 10.9 SOLUTION !!!!!!!
Re: Stuck MIDI notes Mac OS 10.9 SOLUTION !!!!!!!
Unmm... thanks for the tip. It should be noted that not "everyone" is experiencing hung notes.
