It is currently Sun Mar 26, 2017 12:13 am
Text Size
OSX audio MIDI setup rant & ?
Postby Tonio » Mon Apr 05, 2010 2:06 pm
Why oh why does OSX audio MIDI setup default and get stuck to analoge outs? No matter what outplut I choose, and close AM , re open its back to analoge??
Does dumping the plist help?
How is OS 10.6.3 ? I heard that the AM GUI is different, but how about the functionality?
T
MP 3.33 5.1/ OS10.10.5/ DP9.12/ MOTU 828X
MP 2.66 1,1 /OS10.6.8 /DP7.12/MOTU 1224-PCIe424/Lavry DA-10/
Tonio
Re: OSX audio MIDI setup rant & ?
Postby MIDI Life Crisis » Mon Apr 05, 2010 4:53 pm
Either a corrupted plist or config file or both. Dump the config file and the plist, restart A/M setup (no need to restart the Mac) and start over with a new config file. Be sure your drivers for your audio device are also sound (no pun intended). They could also be corrupted, but it's less likely, IMO.
2013 Mac Pro 32GB RAM
OSX 10.12.3; DP 9.02; Track 16 Finale 2014.5
http://www.MIDI-Life-Crisis.com
Postby Tonio » Tue Apr 06, 2010 2:29 pm
Thanks MLC, I'll give that a shot.
Wait,config file- as in MOTU PCI consol?
T
Tonio
Postby MIDI Life Crisis » Tue Apr 06, 2010 2:42 pm
No, config file as in A/M setups.
Postby Tonio » Tue Apr 06, 2010 2:55 pm
I didn't know there is an actual AM file?
Tonio
Postby NazRat » Tue Apr 06, 2010 3:06 pm
I've never been able to get the outputs in AMS to anything other than analog with my 828mkII or 828mk3. Deleting the config or preference file never helped - it always reverts back. It may be something particular to MOTU interfaces/drivers - I dunno. The AMS really doesn't mean much because whatever you set the default output pair in MOTU Audio Setup is what is used regardless of the analog setting in AMS. That's for all apps, not just DP. I use S/PDIF set in MOTU Audio Setup and everything goes there even though AMS says analog.
DP8.06 PT11.2.0 VEP 5.3.x
NazRat
Postby MIDI Life Crisis » Tue Apr 06, 2010 3:08 pm
You can have any number of A/M configurations and subsequently any # of A/M files. They're in user>library>audio>MIDI configurations
Postby MIDI Life Crisis » Tue Apr 06, 2010 3:28 pm
I can't speak to the MOTU or other gear I don't have. M-Audio FW410 for all it's faults does respond to the A/M setup but it is also true that what DP wants DP gets regardless of what A/M setup has to say about it.
Postby Tonio » Tue Apr 06, 2010 8:20 pm
hmm, interesting. Only thing in user>library>audio>MIDI configurations was a mcfg for the PCI consol , no AM files to speak of ?
T
Tonio
Postby MIDI Life Crisis » Tue Apr 06, 2010 8:29 pm
That is an A/M config file. Create a new one in A/M and it should appear there.
Postby Tonio » Wed Apr 07, 2010 7:13 am
nope, just the PCI consol
Tonio
Postby MIDI Life Crisis » Wed Apr 07, 2010 7:25 am
Have you created a new configuration (and named it - like "Test") and then selected it and closed A/M setup? It should appear there. If not, you may have a corrupted plist but I think you've already trashed that. You could also have a corrupted A/M app. It happens!
Again, I don't use that MOTU device, and it is possible (I guess) that it takes over the OS but I doubt it... but you should be able to create a new configuration and see a new file in that window. Mine looks like this:
Postby Tonio » Wed Apr 07, 2010 1:45 pm
I haven't trashed the A/M plist yet.
That is odd, I must have a corrupted A/M utility as I never had the opportunity to create a config as a seperate file. :?
Tonio
Postby MIDI Life Crisis » Wed Apr 07, 2010 2:17 pm
Might just be the Orange Curtain... LOL!
Postby NazRat » Wed Apr 07, 2010 4:34 pm
I really don't think you'll be able to change the output pair of the MOTU interface in AMS after deleting/reconfiguring, etc. The MOTU Audio Setup configuration does override the AMS OS setting. You select the default device in AMS, but any further audio configuration is best accomplished in MOTU Audio Setup. I've been down this road with two MOTU interfaces, though neither was a 1224.
Tonio wrote:That is odd, I must have a corrupted A/M utility as I never had the opportunity to create a config as a seperate file. :?
It is not readily apparent how to create different setups/configs in AMS. It takes some investigation. I doubt you have a corrupted AMS.
NazRat
Next
Return to General Macintosh
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
Who is online
In total there are 2 users online :: 1 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Login Form
