It is currently Thu Jun 20, 2013 4:27 am
Text Size
Mac Troubleshooting Advice
Re: Mac Troubleshooting Advice
Postby papageno » Fri Jul 17, 2009 1:44 am
I paste this from another thread where I wrote.
The method describer below can be handy when the graphical user environment of the computer becomes unresponsible (hangs). Because OS X has built to the UNIX core, the situation where you cannot do anything with your mouse or keyboard but the UNIX core is still running is not rare. I always try this method before doing anything harsh, like pressing and holding the power button.
There is an intelligent way to handle those hangs. Of course one can press and hold the power button, that is the hard way.
When graphic environment crashes and computer keeps hanging, there is a fat chance to be able to reboot from ssh session. For that you have to keep remote login on (preferences>sharing).
I opened ssh application on my iPhone (iPhone has a connection to the LAN via Wifi). You can also use another computer (using terminal.app for example) that is on the same LAN, I just didn't want to go upstairs for that
I logged into my computer with ssh, using an account that has admin privileges (important).
I entered "sudo su" command after login to my computer. That takes you to the superuser mode.
Then I executed command "reboot". The computer rebooted. Everything works fine, including UltraLite.
The routine described anove works only if the graphic environment has crashed and the unix core is still running fine. If one gets kernel panic (I like to call it "kennel panic") then computer is entirely frozen and can be restarted only the hard way.
I have been able to restart my computer intelligently several times after the graphic environment has become unresponsive.
skype: composerkaumann
Software: DigitalPerformer, MSI, MEI, Finale, Bidule, RaySpace, Kontakt, Wallander, Melodyne Studio/Editor (always latest versions)
Hardware: Electrovoice RE27N/D, Audient Mico, UltraLite mk3, MBP 6.2
Keyboards: Fatar Studiologic VMK188Plus & Korg NanoKey
papageno
Postby mhschmieder » Mon Nov 30, 2009 4:07 am
Here are several useful troubleshooting and performance-oriented links from a resource called The X Lab, that I found tonight by happenstance:
Performance tips: http://www.thexlab.com/faqs/performance.html
Freeing disc space: http://www.thexlab.com/faqs/freeingspace.html
Spinning beach ball: http://www.thexlab.com/faqs/sbbod.html
Also, although OWC sells memory and accessories and not Macs, they have a couple of dedicated resources for Mac tips:
Performance tips: http://macperformanceguide.com/Storage-Partitioning.html
Setting up a Mac: http://macperformanceguide.com/Mac-HowToConfigureAniMac.html
I found all of these links while searching for advice on using the internal system drive for Photoshop and iTunes.
As my next iMac will have a 1TB drive, I couldn't think of any other use for all that space, even given the 20-30% rule of free disc space.
My current iMac has a 60GB drive that is 3.5GB away from being full. Nothing can be done about it, unless I learn something new from the tips above (I keep a pretty lean machine and get to know the purpose of each file).
Nevertheless, my initial conclusion is that it is best to continue using external drives for photos and produced music, and not just for audio recording/editing/mixing/mastering and sample libraries.
I haven't had time to read everything linked above in detail yet; I just wanted to do enough research tonight to convince myself that no data should go on the system drive, so that I know better than to order the 2TB iMac.
MacPro Quad-Core Intel Xeon (2.8 GHz, 16 GB), OSX 10.6.8, MOTU DP 8.0.4, BIAS Peak Pro 7.0.1, DSP-Quattro 4.2.2, iZotope RX 2.1.0, Melodyne 3.2.2.2
RME FireFace UFX, Focusrite OctoPre Mk II, True Precision 8, AEA RPQ, Radial PZ-DI, Radial Reamp JCR
Eugenio Upright, Dingwall Afterburner, Yamaha BB-1025X, 60th Ann P-Bass, Fender Select J-Bass, Schecter Ultra Bass, Gretsch Jet Baritone
Yamaha WX5, Hammond 44 Melodion, Hammond XK-3c, Minimoog Voyager, DSI Prophet '08, DSI Evolver
mhschmieder
At least 1GB ram fore every core!
Postby Radiogal » Sat Jan 09, 2010 2:42 pm
THE RAM RULE: At least 1GB RAM for every core..
This means that Macs are sold with to little RAM in the factory configuration.
Keep this in mind and add as much RAM as you can afford.
MAC PRO 6 Core 3.33 GHz, 16 GB RAM, OSX 10.6.8, DP 8.03 MAC and WIN (64bit/Jbridge) AMPGUI Mellow, Logic 9.1.8, Wavelab 7.1, MOTU 24I/O (x2), MOTU 2408 MK3 (2x), WAVES Mercury 9, SSL, UAD2Quad, McDSP, Sound Toys, Sonnox, Sonalksis, NomadFactory, T-Racks, P&M, LexPCM, AbbeyRoad, DSM, VCC, VTM, FGX, Melda, LiquidMix, EWQL SymphOrch/Piano Gold, EZDrm, AAS. Mixingdesk: AMEK Big 44, TK BC-1MK2, SSLcomp clones, GAPPre73, PCM91, TC, FMR, Digitech. Monitors: Genelec 1031, ADAM A7, >40 mics
Radiogal
Postby MIDI Life Crisis » Sat Jan 09, 2010 2:44 pm
Actually, they come with sheep now. :lol:
_______________________________________________________________________
_____________________________MIDI Life Crisis_____________________________
_____________ML.4 • DP 64 bit • 8 core MP/20GB RAM • Track 16______________
Postby newrigel » Sat Jan 09, 2010 3:11 pm
Jim wrote:Also, I recommend Disk Warrior, for cleaning up directories. I don't know if there's a proper order for Applejack then DW, or vice-versa, as they seem to do entirely different things.
It's also good for finding .plist file corruptions too...
newrigel
Postby scooter » Thu Mar 11, 2010 4:06 pm
Hey Steve,
You seem to know about all things Mac.
My 2 x 3 GHz Dual-Core Xeon Mac takes about 5 minutes to boot up.
Once it is up and going it's fine.
I'm guessing this is a little long for start up time.
What would you suggest doing to troubleshoot this?
scooter
2 x 3 GHz Dual-Core Intel Xeon Mac. Snow Leopard 10.6.6.16 gig memory. 2408 MK3 & MOTU 24 I/O. & 828mk3 D.P. 7.22 Lots of plug ins. Reading glasses
scooter
Postby johnnytucats » Thu Mar 11, 2010 4:22 pm
scooter wrote:Hey Steve,
scooter
I'm not Steve, but you might start up in "verbose" mode (hold command-v when you restart) to see where it's hanging. The Mac will be starting up as usual, but you'll get to view what's usually happening behind the scenes.
Then, report back here.
johnnytucats
Postby b.g. » Fri Mar 12, 2010 10:04 am
If the long boot time happened after upgrading to Snow Leopard this may help:
viewtopic.php?f=4&t=38794&start=0
Short answer: In my case, it was fixed with latest PCI-424 drivers.
8 Core 2.8GHz, 6G RAM, OS X 10.8.2, DP 7.24, 2408/1224
b.g.
Postby scooter » Sat Mar 13, 2010 10:14 am
I ran Onyx about a week ago.
Installed the new MOTU drivers.
And tried the command/v trick (didn't know about that) but it's still booting up real slowly.
It gets hung up after the read out in the verbose mode so that didn't help.
I get the light blue screen for about 3 minutes then everything comes up.
I'll try some other stuff and see what happens.
scooter
scooter
Postby bayswater » Sat Mar 13, 2010 10:51 am
scooter
This often happens when the Mac was shut down with servers or networked disks mounted. If these are not available when the Mac starts up again, it can spend a long time looking for them before giving up. It can also happen if your default start up volume is not available.
iMac 27" i7 16G, DP 8.04 & OS 10.8.4, DP 7.24 & OS 10.6.8, MachFive 3.13, 828 Mk3, Micro Express
Dual 2.0G G5 PCI 2G, DP 7.24, OS 10.5.8, 2408 MKII, UAD-1
Postby laurierobin » Sun Dec 05, 2010 12:38 pm
wow that is really generous. I am printing and keeping a copy in my desk--Thank you!
laurierobin
Postby amplidood » Sun Jan 16, 2011 11:02 pm
As far as RAM is concerned...
The current Mac OS has a really funny way of handling memory that's been let go of by other apps. It sits in "Inactive memory", and most of the time takes *forever* to get released again. Sometimes it just won't release it at all. If you are having memory errors and what not, try this little trick.
1. Open Terminal (in your Utilities)
2. Type the word "purge" (no quotes)
3. Wait for it to finish.
Your Inactive Memory has now been converted back to Free Memory. I do this a few times a day and it's amazing that they haven't built a routine to do this automatically.
ampguimods.net andyselby.com themacdaddy
How do I like to work? Out of my "StudioInABag" of course; SwissGear laptop bag (awesome), MacBook Pro (4,1) 2.4ghz/4gb/500gb/Snow leopard, lots and lots of drives, Mbox2Pro, DP, PT, Logic (hardly touch it), Komplete, Reason, too many plugs and VI's to list, Akai LPK25, Korg nanoPAD, wireless keyboard/mouse, Sennheiser 650HD phones...basically i pull four cables out of the bag, hook to the laptop, and go!
amplidood
Postby bayswater » Mon Jan 17, 2011 9:13 am
amplidood wrote:1. Open Terminal (in your Utilities)
I think you need to install the OSX developer tools to get the purge command. I also recall reading that repair permissions invokes the same process (as a side effect).
Postby amplidood » Mon Jan 17, 2011 10:13 am
That's absolutely correct. I didn't realize it was part of the Xcode installation.... my bad. Repairing permissions does it as well, the purge command by itself is just much quicker.
I use something called NerdTool to display active data on my desktop, instead of the menu bar (which I also keep hidden). That number on the top left is my free RAM. Whenever that starts getting down in the 500MB range I run the purge command. Always brings something back.
amplidood
Postby FMiguelez » Mon Jan 17, 2011 10:23 am
Guys, I've found contradicting information about the Repair Disk routine (fsck).
It is always said you need to either, boot from your installation DVD or in Single User mode to use it.
What I want to know is, can I simply boot from another volume (a clone of the main system in a different HD) and run it from there safely?
I read that was not recommended, but I don't see why not, and I don't think I trust the source of that info...
Mac G5 dual 2GHz/4 GB RAM / OSX 10.5.8 / DP 7.24
Tascam DM-24, Yamaha 01v, MOTU 2408 MK3, MOTU MTP AV USB, all Spectrasonics' stuff,
Vienna Instruments SUPER PACKAGE, Waves Platinum, slaved Macs running VI Pro and VE Pro
“In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth.” ― Richard Feynman
FMiguelez
PreviousNext
Return to General Macintosh
Who is online
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
