It is currently Fri Dec 15, 2017 11:04 am
Text Size
macOS Sierra 10.12.5 Combo Update
Postby cuttime » Mon May 15, 2017 8:35 pm
Traveler DP9.51 Unisyn 10.6.8 and 10.13.1 i7 iMac 16G
Re: macOS Sierra 10.12.5 Combo Update
Postby mikehalloran » Mon May 15, 2017 9:27 pm
For those on Yosemite and El Cap, read about and install the latest security updates,
https://support.apple.com/en-us/HT201222
July 2010 iMac 2.93G i7 Quad, OWC eSATA mod, 32G RAM, OS 10.13.1
828mkII FW; MOTU MTP/AV USB with Firmware 2.0.1; DP 9.5.1; IK-NI-Izotope-PSP-Garritan Antares, 32Lives, MachFive 3.2.1
LogicPro X 10.3.2, Finale 25.5, 2014.5, Encore 5.0.7, Notion 6, Overture 5, TwistedWave 1.18, DSP-Q 4.4, QuickTime Pro 7.6.6, SmartScore Pro X2 10.5.5, Toast 16
Test machine: G4-1K Dual Processor: OS 10.4.11 / OS 9.2.2; DP 5.13; Encore 5.05 & 4.5.5; Toast 9.07b, legacy apps
Postby MIDI Life Crisis » Tue May 16, 2017 9:13 am
I don't see anything earth shattering that impact my work. I'll d/l it and wait a bit... Thanks for the heads up.
2013 Mac Pro 32GB RAM
OSX 10.12.6; DP 9.5; Track 16 Finale 2014.5
http://www.MIDILifeCrisis.com
Postby HCMarkus » Tue May 16, 2017 9:32 am
Laptop updated; no issues noted, but this is general use only, no DP.
Postby James Steele » Tue May 16, 2017 11:28 am
I updated. Haven't tested with DP extensively besides loading a typical project and hitting playback... but it seemed to be okay. I did a image backup just prior anyway. :)
JamesSteele.com | Dean Guitars | Facebook | Google+ | Twitter
MacPro5,1 12-Core 3.33, 48GB RAM, macOS 10.12.6, ATI 5770, DP 9.5, MOTU HD192, 24I/O, UAD-2 Duo, Lucid GENx192, HV-3C, Red Type B, Dean guitars, Marshall amps, etc., etc.!
Postby mhschmieder » Wed May 17, 2017 11:34 pm
It pretty much killed two of our computers at work today, but not ones belonging to tech-savvy employees so it's hard to know what that means. I updated my MacPro at work, with no ill effects, and my home computer as well.
iMac 27" 2017 Quad-Core Intel i5 (3.8 GHz, 8 GB), OSX 10.12.6, MOTU DP 9.5.1, iZotope RX 6.0.0
FireFace UFX, Audient ASP880, True Precision 8, AEA RPQ2, Radial PZ-DI & Reamp JCR
Eugenio Upright, 60th P-Bass, Select J-Bass, Geddy Lee J-Bass, BBP35, Viking Bari
Select Strat/Tele, Am Pro JMaster, 57 LP, RevStar RS502T, G5422-12, EXL1, PM2, ES295, T486RB
Masterbilt De Luxe, J100 Xtra, E10D, OM28VTS, E20P-SB, M20, AC530-12, LS8
Yamaha WX5, Hammond XK-1c, Moog Voyager, Prophet 12
mhschmieder
Postby mikehalloran » Thu May 18, 2017 7:56 am
This was mainly a security update and fixed some minor networking issues for work groups connected to a central host.
That it somehow 'killed' two computers makes absolutely no sense at all.
Postby HCMarkus » Thu May 18, 2017 8:22 am
10.12.5 installed on all computers and no OS-related issues noted.
Semi-Related: A friend who installed an earlier OS (El Cap, I believe) Security Update had it kill his Nvidia 980 GPU's driver, forcing him to move to Sierra, because Nvidia no longer supports the earlier OS.
Postby cuttime » Thu May 18, 2017 10:37 am
AOK here with the latest DP 9.13 (72621). I'd read about the Nvidia driver issues elsewhere.
Postby Tobor » Thu May 18, 2017 12:09 pm
As luck would have it, I decided to upgrade my computers from Yosemite on the day 10.12.5 came out. So far everything DP related seems to be fine.
I did have my moments of panic when I couldn't open some downloaded software updates, so thanks for the threads on the terminal commands!!
I plan on putting an SSD in my iMac, do I still have to enable Trim in Sierra?
iMac 2.7 i5, DP 9.02, 10.10.5, Apollo Twin, 828, MTPAV, Toontrack, Spectrasonics, BFD3, Drumcore, Reason 6.5, Live 9, Logic X, Spitfire, Zebra, Miroslav, Waves, Kronos X, MOXF 6, Axiom 49.
Tobor
Postby bayswater » Thu May 18, 2017 1:11 pm
Tobor wrote:I plan on putting an SSD in my iMac, do I still have to enable Trim in Sierra?
Maybe not, but you can check the status in About This Mac > System Report > Hardware > SATA. Scroll down to the SSD in question and the Trim Support status will be listed about 10 lines down.
2009 iMac 27" i7 16G, DP 8.07/9.02/9.5 & OS 10.12.6, Logic 10.3.2, Scarlett 18i8
2011 MBP 16G DP 9.5 & OS 10.12.6, Lexicon Alpha
Dual 2.0G G5 PCI 2G, DP 7.24 & OS 10.5.8, 2408 MKII, UAD-1
Postby mikehalloran » Thu May 18, 2017 2:41 pm
I think so but I've not updated a Mac without an SSD.
The above instructions will show if it's enabled (yes) or not (no). If not, open Terminal and paste the following command:
sudo trimforce enable
Then Enter or Return. It will ask for your Admin password, type it and Return again. Recheck the status. I don't recall that Sierra gives you the dire warning that you have to click through.
What year is your iMac?
Postby Michael Canavan » Thu May 18, 2017 4:46 pm
Kernal Panic during installation, just restarted crashed over and over.
SMC reset Pram, nothing.
Pulled PCIe cards for USB3 and NVME M.2 card, installed, working.
Now to update driver on USB 3 instal, update kext for NVME and instal, hope for the best. :x
Mac Pro 12 core 3.33Ghz. 24G RAM, RME fireface 800, Remote SL, DP9, Live 9 Suite. Falcon, Diva, V-Colletion, NI Ultimate, Maschine, Spark, not enough time.
Michael Canavan
Postby Tobor » Fri May 19, 2017 5:48 am
mikehalloran wrote:The above instructions will show if it's enabled (yes) or not (no). If not, open Terminal and paste the following command:
Mid 2011. I had success upgrading the security bypass with the Terminal command (subsequently reset to default but think I now always have the option for a quick override), so should be able to use the above command when/if I need it.
The local Mac expert said he could configure the new EVO 850 drive to make my current 2T boot drive function as a fusion drive, probably a good idea? The 2011 apparently has an extra SATA port which will allow me to keep both drives installed and running.
Don't know if that would twart plans to load a few VIs directly onto the new internal SSD to complement my already full 1T external SSD. This allocation seems to work very well on my late 2015 SSD MBP.
Tobor
Postby bayswater » Fri May 19, 2017 7:21 am
Tobor wrote:The local Mac expert said he could configure the new EVO 850 drive to make my current 2T boot drive function as a fusion drive, probably a good idea?
Did he/she give a reason to do that?
Next
Return to General Macintosh
Who is online
Users browsing this forum: No registered users and 3 guests
Who is online
In total there are 3 users online :: 0 registered, 0 hidden and 3 guests (based on users active over the past 5 minutes)
Login Form
