I'm not sure where to go with this, but I received a .mov video for a show I'm composing for. The editor told me the dialogue/fx are on A1, and the temp music is on A2. Is this something like a quad-channel audio track? Sure enough, viewing the .mov file on the computer plays only dialogue/fx, while importing the audio in DP plays the stereo temp music only. I'd like to avoid sounding like a complete newbie and asking the editor to split out the audio files for me.
Is there a way to import both sets of channels in DP?
Extracting multi-channel from a video in DP?
- Primary DAW OS: Windows
DP9.5 64bit, Windows 10 Pro 64bit, UA Apollo Quad FireWire interface, Desktop: Intel i7 5820K at 4.0ghz, MSI X99A Gaming 7 mobo, 48gb RAM (DDR4 at 2133 mhz), MSI GTX 960 2GD5T 2GB, 512GB Samsung 950 Pro m.2 SSD (project/system drive). VEP 6
Re: Extracting multi-channel from a video in DP?
Is there an app that will combine the 2 sets of stereo audio into 1? I have delivery specs which specify splits which get sent to editors at the beginning of a job. I'd say it makes you look professional!
Frank Ferrucci
http://www.ferruccimusic.com
If you have Quicktime 7, you can probably delete one track or the other (or disable them) then EXPORT AS WAVE file and save the remaining track. Then reverse the process and mute or delete the other track and export that.
Failing that, just ask for separate tracks. It's ok to ask the editor to do his elfin' job and send you individual tracks. If he refuses, then just refuse to send him elfin' stems and see how he/she likes it...
Just sayin.... grrrrrr........
Haha, I'll try that. Thanks!MIDI Life Crisis wrote:If you have Quicktime 7, you can probably delete one track or the other (or disable them) then EXPORT AS WAVE file and save the remaining track. Then reverse the process and mute or delete the other track and export that.
Yes! This did the trick! Thanks for the suggestion.MIDI Life Crisis wrote:If you have Quicktime 7, you can probably delete one track or the other (or disable them) then EXPORT AS WAVE file and save the remaining track. Then reverse the process and mute or delete the other track and export that.
