It is currently Thu Apr 27, 2017 6:00 am
Text Size
Is anyone using an RME interface with DP9.1 on Windows 10?
Postby PoliticalBonobo » Thu Feb 09, 2017 8:27 am
I just picked up a Fireface UFX and found that it's really not working well at all with 9.1. At 2048 samples, it won't even play (extremely choppy, Playback and Processor meters spiking). I tested on DP9.02 and it plays much better (down to 128 samples), but is still fairly laggy and not very responsive. I'm reaching out everywhere I can (MOTU, RME, forums) to see if this is fixable. Otherwise, I'll have to decide to return it very soon.
Is anyone using a similar configuration? It's hooked up via USB 2.0.
DP9.12 64bit, Windows 10 Pro 64bit, UA Apollo FireWire interface, Desktop: Intel i7 5820K at 4.0ghz, MSI X99A Gaming 7 mobo, 32gb RAM (DDR4 at 2133 mhz), MSI GTX 960 2GD5T 2GB, 512GB Samsung 950 Pro m.2 SSD (project/system drive)
PoliticalBonobo
Re: Is anyone using an RME interface with DP9.1 on Windows 1
Postby kgdrum » Thu Feb 09, 2017 6:41 pm
I'm not a Windows user I use OSX here,this just doesn't sound right RME has great drivers and are known not to be " laggy " at all.
I'm using a RME FF UCX and had a FF800 before that.
Have you contacted SynthAx? They are the distributor here in the USA for RME,Jeff is extremely knowledgable and quite helpful.If you haven't called him I suggest you do asap (954) 626-0674.
Good luck,
KG
2012 Mac Pro 3.3GHz 6 core, 32gigs of ram, OSX10.10.5,DP9.12, RME FF UCX,Great River ME-1NV preamp,a few microphones,UAD2, Komplete 10U & way too many VI's & plugins, Vdrums,Focal Twin 6 monitors, Shunyata PowerSnakes and Conditioners,numerous hard drives... eSATA
kgdrum
Postby PoliticalBonobo » Thu Feb 09, 2017 7:56 pm
I know! This isn't what I expected at all from what I hear of RME!
I'm actually working with Jeff on it, too.
PoliticalBonobo
Postby PoliticalBonobo » Thu Mar 16, 2017 1:48 pm
I thought I'd give an update on this. MOTU figured out the issue with DP9.12 and the RME driver and will provide a fix with the next DP update.
PoliticalBonobo
Return to Digital Performer [Windows]: Troubleshooting/Criticism
Who is online
Who is online
Login Form
