It is currently Sat Apr 29, 2017 12:34 am
Text Size
DP 9 crashing every time during bounce
Postby John Judd » Mon Dec 12, 2016 4:36 pm
Hey Folks,
Just checking to see if anyone else has this issue in the latest version of DP9.
Windows 7 64bit
MOTU Audio Express
I have an existing MOTU tech link in play for this issue.
Set up a project with 0 plugins. Master Fader + 1 stereo audio track with some audio in it.
Select a portion of the track and try to bounce it. DP9 fails at the bounce and needs a force quit via the task manager. Every single time. Here's the catch: if I change the driver to the Windows Audio Instead of MOTU ASiO, it will bounce successfully.
Here's the other catch: DP8 on the same system bounces successfully every time. No issues.
Any advice would be helpful. I will report back here with any info I receive on the Tech link.
Thanks.
John
John Judd
Re: DP 9 crashing every time during bounce
Postby terrybritton » Mon Dec 12, 2016 5:35 pm
This is a long-shot, but check your bundles.
I had Melodyne messing up my ability to add a stereo track. So, I am paranoid about bundles now!
Terry
Computer: Dell XPS 8700-1751BLK | Intel Haswell Core i7 4790@3.6Mhz | 16GB DDR3 1600Mhz | Windows 10 Pro x64 |
MOTU 828 mk3 hybrid- USB
DAWs and Live: MOTU Digital Performer 9.1.3 | Samplitude Pro X3 Suite | Cantabile 3 Performer
Keyboard Synths: Kawai K5000s, Korg Wavestation, Korg Poly800
Controllers: NI Komplete Kontrol S-88, Akai MPK249, Alesis QX49; NI Maschine Jam; Peavey PC 1600x
Rack Modules: Ensoniq ESQm, Yamaha TX81Z, Lexicon LXP-5
Videos: http://www.youtube.com/tbritton33
terrybritton
Postby John Judd » Tue Dec 13, 2016 7:12 am
Thanks for the bundles idea. I had checked this initially, and it isn't a part of the problem.
John Judd
Postby MIDI Life Crisis » Tue Dec 13, 2016 8:26 am
Also, try disabling VST plugins. PSP's VST plugins, specifically, will crash DP 9.1 every time. AUs are ok but you're on a PC so that isn't an option AFAIK. I'll put $$$ on the fact it's a VST plug in somewhere...
2013 Mac Pro 32GB RAM
OSX 10.12.3; DP 9.02; Track 16 Finale 2014.5
http://www.MIDI-Life-Crisis.com
Postby John Judd » Tue Dec 13, 2016 11:35 am
How much $$$ were you discussing, anyway?
No plugins in the project, at all.
Disabled all plugins at the startup of DP9.
Still crashes.
John Judd
Postby MIDI Life Crisis » Tue Dec 13, 2016 12:08 pm
No $$$. I'm not allowed to bet. 12 step program... LOL Sorry that didn't help. It was/is a reliable crash on my Mac every time.
Postby John Judd » Tue Dec 13, 2016 7:22 pm
Thanks for the plugin suggestion. It was a good idea, although this case is different somehow.
John Judd
Postby Robert Randolph » Tue Dec 13, 2016 7:50 pm
If you add a second empty track, does it crash a too?
Robert Randolph
Postby John Judd » Wed Dec 14, 2016 3:57 pm
Yes, it pretty much crashes on bounce in any situation.
After some back and forth with the tech, it is looking like it might have something to do with any project created after the initial project I created in DP9 (which will actually bounce properly, strangely).
I am wondering if all of the project files somehow became corrupted from templates carried over from Dp 8.07.
John Judd
Postby John Judd » Thu Dec 15, 2016 9:38 am
For anyone that followed this post, I'm putting this thread to bed.
I thought I had figured out the problem, yet was mistaken.
MOTU tech really did try to help, but I am afraid it's beyond us to figure this out.
Couldn't get it to work on my W7 rig. When I build a new DAW for W10, I'm sure it will work just fine.
If the term 'Ghost In The Machine' every applied, it would be here.
John Judd
Postby mikehalloran » Thu Dec 15, 2016 11:41 am
Re. the ghost in the machine: I know this is Windows but...
On a Mac, Bounce to Disk crashing is a reliable symptom of a bad stick of RAM. If a certain plug is crashing BTD, eliminate it, of course, but if there's still a problem, RAM is where I look for—and find the culprit.
If you're building a new machine and the ghosts vanish...
July 2010 iMac 2.93G i7 Quad, OWC eSATA mod, 32G RAM, OS 10.12.4
828mkII FW; MOTU MTP/AV USB with Firmware 2.0.1; DP 9.13, 9.02, 8.07 64bit, DP 7.24; IK-NI-Izotope-PSP-Garritan Antares, 32Lives, JBridge, MachFive 3.2.1
LogicPro X 10.3, Finale 25.3, 2014.5, Encore 5.0.7, Notion 6, Overture 5, TwistedWave, DSP-Q 4.4, QuickTime Pro 7.6.6, SmartScore Pro X2 10.5.5, Toast 15
Test machine: G4-1K Dual Processor: OS 10.4.11 / OS 9.2.2; DP 5.13; Encore 5.05 & 4.5.5; Toast 9.07b, legacy apps
Postby John Judd » Sun Dec 18, 2016 5:23 pm
RAM is of course, a good idea.
But: DP8 bounces like a champ. My other main DAW bounces like a champ.
I think there is something specific to my DP9 installation that has gone south and can't be fixed (or I am not willing to continue on this miserable journey to find out what the solution is when my other DAW is my main software and DP8 works well).
Funny that bouncing in DP9 is literally the only feature I didn't test before purchase.
Thanks for the suggestions, folks.
Happy Non-Specific Holiday Celebration to all!
John Judd
Postby swander » Fri Dec 23, 2016 7:00 am
Hi John:
I was having the same problem. DP 9.12 on a new Windows 10 machine. Simple bounce to video was crashing DP every time. MOTU tech support suggested installing DP 8 and trying it. That worked - my test file bounced just fine. (albeit very slowly). Then I went back to DP 9.12 and tried the test file again, and now DP 9 bounced without crashing. Weird. The only change on the machine was a Windows auto-update, and iTunes for Windows update and installing DP8. Somehow that combination made everything work.
About the slow bounce time: I set up a test file with two stereo audio tracks and a .mp4 video file. I bounced an 11-second section on my old mac 2008 running DP 8 and it bounced to a .mov file in 5 seconds. I did the exact same bounce on my Windows 10 machine and it bounced to a .mp4 file in 1 minute 20 seconds. I changed from the ASIO driver to the Windows driver and that lowered the bounce time to 1:04. Anyone know if this is just a Windows thing?
Also, there's no Quicktime Export Options dialog box after I OK the bounce dialog box. Is the inability to include film scoring events another Windows thing?
swander
Postby John Judd » Fri Dec 23, 2016 8:23 pm
Hi swander,
I'm not sure it's exactly the same event we are describing.
I wasn't dealing with video whatsoever in these projects.
And DP9 would render odd lengths of corrupted audio and then would hang.
On my generic Acer Windows 10 machine (not a music rig), I had an active demo of DP9 that worked flawlessly. (Although I did not test your video bouncing)
I use two DAWS, and DP compliments the other one nicely. Once I build a new W10 rig I'm confident that things will work just fine.
John Judd
Return to Digital Performer [Windows]: Troubleshooting/Criticism
Who is online
Who is online
Login Form
