It is currently Thu Mar 23, 2017 3:14 am
Text Size
Problems regarding bank select for my external synth
Postby PigSpeakers » Fri Sep 30, 2016 1:27 pm
I've got a Casio XW-P1 connected to my computer via USB and I can't for the life of me get access to all of the patches that are available on the keyboard. There's no midnam file for the synth, so all of my patches appear as "Patch 1, Patch 2,..." All of these patches are the default general MIDI sounds. Granted, they're all coming from the synth, but there's so much more to the keyboard than general MIDI.
I've tried changing the bank by inserting a patch change via event information/event list. Every time I place a different number in the bank select 0 or bank select 32 window, it does nothing. And if I pick a different patch from the drop down menu, they either default back to 0 in the event information screen, or "-" in the Event List screen. If I try and do anything in Event List it often leads to a freeze and I have to hard-exit DP.
What am I doing wrong? Is there something I need to change on the synth side or is it on the software side? I created a bundle for the XW-P1 with channel one set to transmit and then channels 1-16 set on receive as well as program change and bank msb. Nothing else is checked. The I/O is set to CASIO-USB.
PigSpeakers
Re: Problems regarding bank select for my external synth
Postby reedster » Sat Oct 01, 2016 8:38 am
MIDI implementation in the manual does not indicate CC32 support - I would focus on CC0.
You might try changing patches while recording - if the message records you will have the format.
I don't know Windows... if there is a way to assign the output to a similar synth you can observe the behavior and determine a method to get the results you want.
sounds like you already have USB On
There's full details in the MIDI implementation guide XWP1_midi_EN.pdf available from world.casio.com
One thing the guide indicates after the Bank Select, a Patch Change must be received for the sound to change.
MacBook Pro 9,1 15" 16gb | 10.11.5 | DP 9.1 | xAir | NI | WIVI | Garritan | Izotope | Bidule
reedster
Postby PigSpeakers » Sat Oct 01, 2016 8:29 pm
Thank you! I figured it out, but it had more to do with the synth being weird in how it sends. I had to go to the mixer mode on the synth and then it let me pick a different sound for each of the sixteen channels. Hopefully the next synth I buy is a little more straightforward.
PigSpeakers
Return to Digital Performer [Windows]: Troubleshooting/Criticism
Who is online
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Login Form
