It is currently Sat Jan 20, 2018 8:17 am
Text Size
Komplete Kontrol S61 and Software issue with DP 9
Postby rean1mator » Fri Jan 22, 2016 9:37 am
HI All,
I'm having some issues with getting my S61 Controller working nicely with DP 9 on Windows on multiple fronts.
1. Can't get DP 9 to recognize MIDI inputs from the S61 to control VST instruments
2. Can't get plugin instruments to work either DP plugins or NI Plugins.
I upgraded to DP 9 last night and everything completely stopped working. I was mostly working in dp 8 and sporadically working in dp 9 before it completely stopped working out of nowhere.
In DP 8 I was able to load all NI Plugins as an instrument, add corresponding MIDI track and everything was fine except for being able to load NI Komplete KOntrol as a plugin. It became unstable with kontrol plugin.
IN DP 9 the same thing at first and then all of a sudden everything Kompletely stopped working for both dp plugins(mx4) as well as all NI Plugins. When I chekc the MIDI monitor I don't see any MIDI input signal coming from the S61.
I can open up Komplete control as a stand alone and everything works fine however.
I'm at a loss as to what to do at this point to troubleshoot. Any recommendations is appreciated.
rean1mator
Re: Komplete Kontrol S61 and Software issue with DP 9
Postby waltincal » Sat Apr 16, 2016 8:39 am
Were you able to get Komplete Kontrol working with DP9?
waltincal
Return to Digital Performer [Windows]: Troubleshooting/Criticism
Who is online
Users browsing this forum: No registered users and 2 guests
Who is online
In total there are 2 users online :: 0 registered, 0 hidden and 2 guests (based on users active over the past 5 minutes)
Login Form
