DP and A&H ZED R-16 Desk
rockydill
Post by rockydill »
I am wondering if anyone is successfully using ZED R-16 desk and using MIDI facility to control DP? Have been wrestling with this for some time but so far without success. All help welcomed!
RROY
Re: DP and A&H ZED R-16 Desk
Post by RROY »
ZED R 16 and DP 8.07 working fine here. If I remember correctly you have to assign the transport controls on the ZR 16 in the commands window of DP. There was some set up info for the mixer, you can get that from A&H.
rockydill
Post by rockydill »
Have finally managed to get faders working but not Transport.
It's has been very much trial and error. Mostly the latter.
If anyone knows any more about Transport settings in Commands etc please advise.
RROY
Post by RROY »
Open the Commands window go to the the command you want to assign, click on the MIDI Event for that command to open the box, then hit the appropriate button on the Transport controls on the ZED R 16. That should enter a MIDI note number. You have to do that for each transport command. Source should be Allen and Heath Firewire. Make sure Transport Master is enabled. It's near the top of the Commands window. Hope that helps.
