Hello all,
I used to use DP3 and I start to use DP8.07 on Win8.1 64bit.
I have Sampletank3 and Ultra Analog VA-2. Both of them don't recognize Volume and Pan.
Of course automation play button is on.
In the case that I do same operation on DP3, MacOS9 and Sampletank free, Sampletank recognizes Volume and Pan.
I must be missing some setting on DP8. I'm happy if I have any advice.
Thank you,
Kyon
No CC possible on VSTi
- kelldammit
- Primary DAW OS: Windows
Re: No CC possible on VSTi
you may need to use MIDI learn in those plugins to set the volume to respond to cc7 (or go into MIDI learn mode, and change the volume control of the MIDI track in the mixer...not the instrument track!).
I had to do that with tremor.
good luck!
good luck!
Feed the children! Preferably to starving wild animals.
ASUS 2.5ghz i7 laptop, 32Gb RAM, win10 x64, RME Babyface, Akai MPK-61, Some Plugins, Guitars and Stuff, Lava Lamps.
Thank you for your comment.
I'm sorry for late reply because I have not visited here lately.
I confirmed that I can control Volume and Pan using MIDI learn.
Thanks again !
Thanks again !
