Is there no way to change the vertical tempo scale from 0 to 400 to something more focused around the actual project tempo?
This is rather coarse resolution for working in the 100bpm range. The single zoom only goes to 0 to 180. Couldn't find anything in the online help about it. Manual is at the studio, will have to look more tomorrow.
Also, when the conductor track is expanded to, say, half the pane or more, the mouse scroll wheel resolution is also rather coarse and notes end up at either the top or bottom of the pane, making it necessary to grab the rather tiny window pane scroll bar and adjust.
Any custom setting to force notes to the center of the view without having to use the mouse and manually position the scroll bar every time it is opened?
Conductor track questions
Re: Conductor track questions
Move your cursor over to the ruler on the left. It becomes a magnifying glass. You can then select the range of tempos you want in the graphic window.
